Thread: signum
    Regular Member cockney16v's Avatar
    stoke on trent
    Default signum
    can anyone tell me how to change a rear wheel bearing on a 2004 signum
    Here, there and every where!
    Complete hub change m8. It's all one unit
    stoke on trent
    how does then hub come off i no you have to take the brake caliper and disc of then what
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Once the Caliper and disk are off, unplug the ABS wiring, undo the 4 retaining nuts and remove the bearing unit and brake disc shield from the hub carrier. Refit in reverse. Looks easy in the Haynes compared to the fronts. Think the unit is about £85 on flea bay.
    stoke on trent
    do they do a hayne manual for the vec/signum now and where can i get one from
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Halfords mate, about £18. Although you might find it cheaper on flea bay.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I got my front one from this company. Came in 2 days Very happy with it.
    South east
    You're not getting a rumbling noise from the rear are you? If so, could be tyres worn right down on the inside edges...seems to be very common on Vec-c's and Signums and symptoms seem very similar to bearing problem.
    Nr Cardiff
    I was going to suggest that.
    stoke on trent
    no there play in the n/s rear
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
