Results 1 to 10 of 15
Thread: TB3 Upgrade?
    Regular Member siross's Avatar
    Oct 2007
    Default TB3 Upgrade?
    Has anybody done "The Big Three" in there vectra c?
    Basically upgrading the stock earths under the bonnet to limit voltage drop in large audio systems.
    The three are:
    1) Battery to Chassis earth
    2) Charging wire between the battery and the alternator
    3) Alternator to chassis earth wire.
    This needs to be done on my vectra but I have no idea how easy/hard it will be.
    I've heard somewhere that the alternator is incredibly hard to get to on the vec c which might prove very difficult whilst doing this task!
    Thanks for any help guys
    Simon
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    What are you planning on running?
    [Ex]Admin Duncan's Avatar
    A flux capacitor by the sounds of it!
    surrey
    Trim : SRI
    Year : 53
    Oct 2007
    Really anything over 500rms should be upgraded to 4awg.
    I will be running ~2.5k rms
    surrey
    Trim : SRI
    Year : 53
    The three are:
    Done a few installs but nothing near the 2.5k rms mark. You must be planning on running big bass!
    So I suppose you will use a BIG power caps as well. What about an additional battery and split charger.
    I also went for loud (with quality ) but with minimum power- it can be done. What amps, headunit you looking at?
    Oct 2007
    Quote Originally Posted by joules2.0t View Post
    I'll be running a burning desire 2 (2000rms at 1ohm) running 4 x 12" spl dynamic subs and a DLS A4 (250rms x2) running a set of Oz Audio Matrix components.
    I wont be adding a power cap, they do more harm than good.
    Ideally I would like to add a second battery but as an interim fix I would like to do the big three but even so, it needs to be done to prevent voltage drop no matter what batts you put in there.
    Fwiw, the rest of my system will be:
    Alpine ida-x001 ipod head unit (with 6 cd changer)
    Phoenix Gold EQ25x processor
    And hopefully an audiocontrol epicentre
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Holy cowel batman are you planning to contact Aliens or something?
    That is going to one nice setup, keep us upto date as you do it. Maybe run a how2 on it?
    Oct 2007
    There is a thread in here called "and so it begins"
    edit heres the link http://forum.vectra-c.com/showthread...ghlight=begins
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by siross View Post
    Missed that one! Looks good so far
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
