Thread: dodgy main push button on climate control?
    Regular Member effone's Avatar
    Bedfordshire
    Default dodgy main push button on climate control?
    hello all,
    apologies if this has been covered elsewhere, couldn't find anything in the search option about this though...
    my main rotary dial for my climate control is a bit hit and miss when you push it in - i.e push to get a/c menu up, then push again to check / uncheck option boxes etc...
    it sometimes works ok, and on other times needs a few presses for this to work...
    does anyone / has anyone got anything similar...
    hopefully this'll be covered in the warranty i got with my car if it has failed..!!
    any help, as ever, gratefully received...!!!
    ian b
    [Ex]Admin Duncan's Avatar
    Never had the problem but warranty should cover it I'd have thought. If all else fails maybe pop the CC unit out and give the switch contact a good spray with contact cleaner.
    yep, dodgy contacts in the rotary switch.. usually resorts to a new unit.. but warranty will cover it
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Quote Originally Posted by effone View Post
    I have the same problem, but unfortunately my warranty has expired
    Any ideas how much a new unit could cost, and how easy is it to fit?
    dead easy to fit, unit just clips out forward..wiring is on multiplugs
    guide price £80 for a new unit..
    Bedfordshire
    cheers for the info chaps,
    i'll get onto the dealer when i get a few spare minutes...!!
    ian b
  1. think before you push that button
    By hoochydady in forum Comedy & Humour
    Last Post: 25th November 2012, 18:08
  2. HVAC control main button doesnt work!
    By Johnny-B in forum Troubleshooting
    Last Post: 26th June 2012, 18:27
  3. Push the button???
    By Big Sig in forum Comedy & Humour
    Last Post: 13th April 2012, 16:30
  4. Auto Button on Climate Control Not Illuminated
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 19:02
vectra climate menu button
