Results 1 to 3 of 3
Thread: New throttle body plate(s)!!
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Default New throttle body plate(s)!!
    My old man kindly did a technical drawing of a plate that is needed for my new 2.0 SC throttle body to fit, took it to work and had some plates laser cut for me!
    I needed to have more than one plate as otherwise the body of the TB presses up against the runner on the inlet manifold (this wouldn't be a problem on the normal 2.2 manifold), so I have had 5 done! With 4 spares so I could drill the holes myself if the other plates were out for some reason, but they are fine - yay ! I have ordered a length of tubing for inlet pipework, with a fitting welded into it for my breather hose. Once that is here I need to get it squashed a bit so it will fit right, then we are good to go for the remap hopefully!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Mmm, more shiny bits. You should have got more made mate and punted then on Z22se like the ECU brackets. So when you fitting the TB then? As you might have seen on your other thread I have something in mind.........1 day to go
    May 2007
    Is that about the K&N Apollo??
    Might be this week sometime for fitting the TB?
  1. Throttle body butterfly plate removal (someone had to do it)
    By diesel dog in forum Diesel Engine related
    Last Post: 15th March 2012, 12:52
  2. Throttle body
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 17:32
  3. Throttle Body
    By vectraestate in forum Engine & Drivetrain
    Last Post: 25th March 2010, 17:33
  4. throttle body
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 17th February 2010, 18:55
  5. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
