Thread: Lightweight Flywheel
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Lightweight Flywheel
    Is there any way of lightening the flywheel or anybody know where i can get a lightened one?
    Dan
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    try a quick search matey.
    i'm sure all the C's (awaits confirmation) have this stupid dualmass flywheel.
    iirc it is replaceable but i havent a scooby who makes them or what the result would be.
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    From what I understood, you can't replace the DMF with a single plate one as the clutch slave cylinder would be overextended.
    I am sure there is a way around that though??
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Also this wouldnt be a good idea on a diesel because it will lose some of its grunt on pulloff if i'm correct.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Nah, it wouldn't loose grunt, but it might run rough and would hurt your fuel economy. You could change the dual mass flywheel but you would have to have something custom made and for that you would need the Dual mass flywheel to work from.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You definitely need to stick with the DMF, otherwise your gearbox will see much longer if you swap it for a single plate.
    Gazza4
    Jul 2006
    Northampton
    Trim : Sri
    so to sum it up, i can get a custom made dmf, made from lighter materials. Overall probably not worth it for the performance return
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You might get off the line a bit quicker, so if you do alot of traffic light racing it might be worth it...not.
    The only benefit I can see is with reliability and heavy tuning, the dual mass flywheels have been known to fail but I haven't heard or any on the 2.2DTI. Tuning wise, the DM-flywheel is tuned and when you modify you change the characteristics which can lead to rumbling and heavy vibrations.
    All in all, I wouldn't bother unless you were changing the clutch and adding an LSD at the same time. Not sure the 2.2DTI makes enough power and torque to benefit from said though. Do you get alot of wheel spin and torque steer?
    Jul 2006
    Northampton
    Trim : Sri
    with the tc off i do, i was just curious really because i was looking into a bit of heavy tuning but not tearing the engine apart. Im more interested in strengthening the fuel pump to run much higher pressures
  1. dmf to smf flywheel
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 25th November 2012, 22:34
  2. Lightweight Flywheel For C 1.8 sri
    By Jateu_01 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 20:22
  3. Flywheel?
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 16:17
  4. Replies: 2
    Last Post: 12th June 2007, 00:56
  5. Now its the flywheel!!!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 26th October 2006, 19:17
vectra c 1.9 performance flywheel
vauxhall 150 cdti lightweight flywheel
