Thread: replacement aerial base/ info required
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default replacement aerial base/ info required
    The rubber cup on the base of my aerial is looking rather perished so i have decided to replace it.
    Now i have been looking through various section,s and how to to try and find out what is the best way to remove the roof lining on my signum . mine has the canoe installed down the centre line
    Q1 Do i need to remove the canoe,and how is that best done
    Q2 Do i need to remove all of the headlineer to access antenna mount,or is there an easy way to access aerial mount .
    thanks in advance
    regards bob
    Q1 - No, no need to remove the overhead storage.
    Q2 - you just need to drop the headlining from the back. You'll probably/possibly need to remove the rear grab handles to let you drop the headliner that bit further, then you'll see the nut holding the base on.
    Bob, Andy L is the man to ask, he has changed his roof lining in his facelift to the one like ours with the cubby holes in.
    Duplicate threads now merged.
    Engine : 2.0DTi
    Mileage : 73350
    Cheers duncan thanks for info
    and please can you delete similar thread
    regards bob
    No probs, and already done as per my post above.
  1. Aerial Base
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2012, 14:15
  2. Aerial Base seal replacement
    Last Post: 27th December 2011, 10:36
  3. Aerial Base
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2008, 18:05
