Thread: 314mm brake upgrade
    Regular Member PeteRs's Avatar
    here or there
    Default 314mm brake upgrade
    hi is there any other parts i need to get these to fit i have the discs pads calipers carriers thanks
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Provided you've got the tools, Brake Fluid & thread lock I think you've got al you need. I found that the pad wear sensor wire was a bit tight but it does still fit ok!
    here or there
    ok ta i didnt want take em off & find i needed bolts or summat else thanks
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    You'll need new carrier bolts and the brake pipe washers,about 8 quid in all from Vx.
    Mar 2007
    Southport
    Must admit I didn't bother with the bolts but sorry forgot about the washers - amazingly my local Vx dealer had to put in a special order for them - they are not a stock item. Does that mean they usually reuse the old washers??
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The washers are ally so they shouldn't reuse them but i bet they do!.
  1. For Sale: 314mm brake upgrade
    By Craig1985 in forum Parts for sale
    Last Post: 3rd May 2012, 15:11
  2. 314mm brake upgrade
    By peteopc in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2009, 11:43
  3. GSi Brake upgrade to 314mm?
    By fuzzbomUK in forum Handling & Braking
    Last Post: 16th September 2008, 12:57
  4. 314mm upgrade brake kit??
    By Jay Kay 313 in forum Suspension, Wheels & Brakes
    Last Post: 6th September 2008, 12:13
  5. 314mm brake upgrade
    By steve1975l in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 21:12
