Thanks Thanks:  1
Likes Likes:  26
Page 2 of 15 FirstFirst 123412 ... LastLast
Results 11 to 20 of 143
Thread: 314 vs 345
  1. #11
    Tyneside
    Surely part No's on the calipers will be the same if they're the same caliper. From the looks of it they are exactly the same as has already been said. Hmmmmm brain starts ticking LOL.
  2. #12
    from those pics it does just seem to be the caliper brackets that differ, unless it's the angle they are shot at... the pads should transfer over as well, so hopefully the police one's should also fit..
  3. #13
    Tyneside
    So all is needed is discs and carriers And I would also need to check if they clear the 17's.
  4. #14
    Quote Originally Posted by mark1319 View Post
    Oh mine started ticking as soon as I saw the first pics!
    It could be like the thing with the 278mm and 292mm rear calipers. Look the same but they do have slight differences but you can still fit a 278mm caliper over a 292mm vented disc with a bit of tweaking (it's the ability of the 292mm calipers to span the extra width of the ventilated disc that basically makes them different).
    With both the 314mm and 345mm front discs being vented, and presuming the same width?, then maybe there is very little difference between the two calipers?
    Very interested to see what test_uk comes up with tomorrow.
  5. #15
    Ah, I have a feeling not a cat in hells chance! The 345s will clear most 18s, not all though - all depends on the offset. I'd need to check if they'd clear my 18s, but I'm positive they won't clear a 17? - unless anyone else knows differently?
  6. #16
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    Think about this.. If the pads are the same size between the two discs will having a larger disc actually generate any more stopping force if the pad contact area is the same?
    Either way I'd do it just cause the disc would fit
  7. #17
    314's are tight on 17's.....345's are going to be very very close running.. i'd be surprised if they went under.
  8. #18
    Quote Originally Posted by plasma View Post
    the answer is yes... a bigger disc will always provide more stopping power than a smaller disc for the same pad size.. force by extension dad.. simple physics from a simple fella..
  9. #19
    Tyneside
    Well 345's are whats on the Plod cars and they run 17's, but obviously if they are made to fit the 345's inside them. I asked a guy and got a pic of them inside the 17's. will grab the pic
  10. #20
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yes because you are further away from the fulcrum. Its easier to stop a wheel from the edge than from the centre.
    EDIT, how slow am I.
https:www.vectra-c.comforumshowthread.php50741-314-vs-345
vectra c 345 vs 314
zafira vxr brake calipers
saab 345 caliper
vectra c 314mm brakes
vectra c 314
opc 345 caliper part number
314mm opel brake carriersopel 345 mm caliper carriersopel 345 caliper345 disc alfa calipersaab 345mm caliperany difference 314mm and 345 mm caliper saab 9-3opel 345mm calipervectra 345mm brake upgrade93188029bvectra opc 345mm prakesvxr vectra c brakecaliper carrier vectra cvectra c front brake calipervectra 314 oder 345 empfehlenswert Vectra vxr front caliperVectra vxr front carrier caliperVectra vxr calipervectra c 314 mm
