Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 124
Thread: 314 vs 345
    May 2008
    UK
    Default 314 vs 345
    Hi guys
    I recently picked up a set of vxr front & rear brakes for £200 , have just finished cleaning them up so thought i would post some pics, Also managed to get a set of the 314mm fronts off the Saab dealer in Milton Keynes (thanks James + Amar) so some pics of the front calipers to show the differences, just need to fit the vxr set now
    [Ex]Admin Duncan's Avatar
    So that last pic, is that a 345 and 314 caliper next to each other? They look the same size.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    either way they are mahoooooosive
    Midlands Mod Shop - NFFC.
    Feb 2006
    Guttedsville
    Carrier bracket is bigger, unless it's the camera angle.
    May 2008
    UK
    hi Duncan, yes they are the same length but the mounting holes (caliper to hub) are further out on the vxr's & a few other small differences
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Doesn't look to be a huge difference between the 2 front callipers or am I missing something?
    My ex Saab 314's are getting better & better - with a few hundred miles on them they are now very positive & responsive, I'm well pleased.
    A big thank you to James + Amar from me too
    Quote Originally Posted by test_uk View Post
    Righto.
    Hmm, I wonder if there is any mileage then in using a 314mm caliper on a 345mm disc? and having increased stopping power?
    Any chance of you seeing if a 314mm caliper will fit to the 345mm carrier?
    May 2008
    UK
    another piccy
    Righto.
    will have a look tomorrow and get some pics up
    please do... as i'm about to change up to 345's..
vectra c 314mm brakes
vectra vxr Caliper diameter
vectra c front brake caliper
vectra c 314
vectra 314 oder 345 empfehlenswert
Vectra vxr front caliper
Vectra vxr front carrier caliper
Vectra vxr caliper
vectra c 314 mm
314mm vs 345mm
caliper vectra vxr upgrade
