Thread: fan belt
    May 2008
    fife
    Default fan belt
    can you tell me how to adjust the belt please as it squeels in the morning when its started
    it's automatically tensioned.. so adjustment isn't possible.. may i suggest a new belt, as that usually helps..
    May 2008
    fife
    cheers how much do they cost and is it a big job
    dependant on the engine size, it's very easy to moderatly easy... the belts are about £20 a throw, again dependant on engine size..
    May 2008
    fife
    2.0 dti
    it's dead easy.. draw a picture of where it runs around the pulleys...
    the tensioner has a 15mm head on it, use a big spanner to let the tension off, then swap the belt over making sure it wraps the correct way.. then pull on the tensioner again and refit the belt to it.. let go of the tensioner and it's job done.. you may find it easier if the airbox is removed ( it just pulls up and out)
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    How easy it to change the fan belt on a 2t?
    South east
    Don't collect my 2.0T Signum until Saturday so can't check it myself....but don't Vx use electric fans anymore?
    it's not a fan belt.. it's an auxilliary drive belt....
    take the airbox out, and remove the lower sheild in the inner wing... 15mm spanner for the tensioner, and it's one off, one on...
    South east
    What does it drive? Alternator?
  1. 1.9 cam belt
    By J P S in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:13
  2. Belt changes on a 1.8 VVT
    By PeterVV in forum Engine & Drivetrain
    Last Post: 27th April 2011, 21:53
  3. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. fan belt ??
    By arniedavo in forum Engine & Drivetrain
    Last Post: 10th September 2008, 01:16
