Results 1 to 10 of 11
Thread: loose steering wheel
    durham
    Default loose steering wheel
    has anyone had any problems with their steering wheel rocking from side to side if so was it sorted easily cheers patrick
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Remove your airbag and tighten the torx bolt up underneath.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    T50 bit will do it
    durham
    is air bag easily removed cheers
    Jun 2007
    in a white box
    Northampton
    Engine : A20DTH
    Mileage : 88000
    a small flat bladed screw driver is needed, check if there is a how2 as it can be a pain in the @rse and another time dead easy. Which I could explain but not good, think its best done with a video!
    Jun 2007
    in a white box
    turn the steering wheel a quarter turn, then feel round the back. you should feel two small holes top and bottom. you need a small flat blade screwdriver (not too small).
    wiggle it about. from memory its more towards the steering column that you need to move the screwdriver head towards. Hold the airbag and pull it out when you see it move.
    REMEMBER TO DISCONNECT BATTERY FOR ABOUT 20MINS
    durham
    cheers i,ll give it go.
    South east
    Wear a crash helmet in case the airbag goes off.
    joke.
    fairly un funny one at that too..
    anyone attempting anything involving the airbags MUST disconnect the battery on the car and walk away for 15mins to allow the firing capacitors to leak down..
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Alternator problemish / wheel loose, fallen of
    By partypulp in forum Engine & Drivetrain
    Last Post: 4th July 2011, 14:08
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. rear wheel seems loose but nothing obvious can be found
    By craigbarlow18 in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2009, 20:12
vague steering on signum
vectra c steering feels weird like a loose wheel
