Thread: Help with gear stick
    gwent
    Default Help with gear stick
    Can anyone help me with a gear stick problem i brought a VXR gearstick off EBAY when it arrive it was only the top half witch was the gearstick and the top half lever pod. Can i still change my lever for vxr one? In the hanyes workshop manual it does not recommended and if so can i change it without moving the slector cable?
    why do you want to change?.. if it's just for the gearknob, then remove it and transfer it to your current gearstick
    gwent
    you can't just change the knob because the vxr one is bulit to the gearstick so I would have to change the lever for my Sri lever?
    the sri one is also part of the gearstick.., but it can also be removed.. as can the VXR one..
    a tap up from underneath can remove the sri one, and then you can rebond on the VXR one..
    gwent
    But the VXR knob is different because the reverse button is bulit in to the knob not like sri one
  1. Gear stick
    By Puffalo bill in forum Bodywork & Interior
    Last Post: 4th January 2012, 18:34
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. gear stick
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 16:32
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
