Page 1 of 8 123 ... LastLast
Results 1 to 10 of 75
Thread: Anti-Roll Bar Bushes-How??
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Anti-Roll Bar Bushes-How??
    Hi all and apologies in advance for troubling you.
    I was looking for a How 2 on changing the rear Anti-Roll Bar Bushes, and also a pointer as to how many there and where these are located?
    Pics would be very handy.
    Also, from experience, does anyone know how difficult these are to change and are they easy to get to...DIY surgery???
    Thanks all.
    very easy DIY...
    they are secured by a 13mm headed bolt..just undo the bolt, remove the bridle clip.. remove the rubber and replace it with the new one.. replce the bridle and do up the 13mm bolt again....
    total time is under 5 mins from when you have the wheel off..
    Birmingham
    very easy DIY...
    Thanks Bud. I am really putting off changing the control arms, and someone on here mentioned that thye had the same problme and changed these and it was problem solved. Im hoping I have similar luck. Whats my chances???
    no better than 50/50.... but they are easier and cheaper, so it's well worth a punt..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have u checked the rear control arms. While the car is on the road grab the top of one of the rear wheels and see if you can pull it back and forth. If u have movement then replacements needed. First time I checked my girlfriends vectra c estate there was about 1-2 cm movement which explained why the back end would go all over the place!
    Birmingham
    I was hoping you wouldnt say that! Darn....oh well, I know where my weekend is going.
    Birmingham
    Quote Originally Posted by merikiito View Post
    To be honest, the back seems pretty stbale to me....but nevertheless, I will check this. So basically, when the car is sat on the drive, leave it on the ground and tug at one of the back wheels from the top puilling it towards me??? And if there is play/movement, then these are f0ckered? Its just such a ****ey design to get to that one bolt.....any easy way to see it so i can open the son of a gun??
    you need to rock it when it's jacked up, or the suspension load will stop it moving even if it is worn....
    if there is any movement at the top arm, then yes the arm needs changing..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No u dont, it has to be checked when its on the ground. The load does not stop it moving. It will not show up if it is jacked up off the ground. Take my word on it as I have checked loads of them.
    Yep just pull it towards you and then push it back.
    lets just settle to differ shall we.. rather than fall out over this, but it does show up when the car is raised..and if the car is raised, supported and with the wheel off it's far easier for folks to see any movement that may be occuring on the top mount, or any other bushings rather than just guessing it's the top arms because 'it moves'. For folks working at home ( which is what this section is aimed at) it needs to be as simple a test as it can be, while still being as accurate as possible..
    Also, the MOT test calls for the suspension to be checked with the vehicle raised and the suspension on droop..not in the 'loaded' condition with the cars weight on it..
  1. Anti-Roll Bar Bushes
    By Monkgti in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2013, 20:56
  2. Anti roll bar bushes
    By Mark-R in forum Handling & Braking
    Last Post: 27th April 2012, 14:13
  3. Anti Roll Bushes...Which ones?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2009, 12:17
  4. anti roll bar bushes
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2008, 17:53
  5. i think i need anti roll bar bushes but!!
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 13:30
vectra c anti roll bar bush replacement
how to change vectra c rear anti roll bar bushes
vectra c anti roll bar bushes
how to change anti roll bar bushes vectra c
vectra c rear arb bush worn site:www.vectra-c.com
change vectra c anti roll bar bushes
vectra arb bushes
gumice vpetja stabilizatorja
vectra c rear anti roll bar replacement
