Thread: Problem when turning engine off!
    Nov 2007
    Stourbridge
    Default Problem when turning engine off!
    last night whilst driving my engine fault light came on there was nothing wrong with the car untill i switched it off and the whole engine vibarated as if all the engine mountings had gone after stopping and stating it the light in the clock went off and everything went back to normal!
    any ideas whats wrong with it?? before something really goes wrong with it?
    its a 1.9 cdti 04 reg!
    Jul 2006
    Mexico
    Have you checked the battery lately?
    On the other hand you should check for any falut codes stored
    HTH
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If it was a petrol engine I'd say it was pre ignition or detonation causing 'run on', but I don't know if a diesel engine with electronically metred fuel delivery can do that!?!
    all i can add, is thats it's really important to get the engine codes read ASAP.. it has a fault, and the only way to be 100% sure is to get those codes read
    Jul 2006
    Mexico
    See...I learned from the best
    Nov 2007
    Stourbridge
    ive booked it in to have any codes that have been stored read see what comes up!
  1. Intermintant problem with not turning over
    By kieronh84 in forum Engine & Drivetrain
    Last Post: 20th February 2013, 23:14
  2. Indicator problem when turning
    By gspott in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2012, 14:05
  3. awfull shut down when turning engine off
    By justin32 in forum Engine & Drivetrain
    Last Post: 3rd April 2012, 22:50
  4. engine problem
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 19:30
  5. Engine cutting out when turning right
    By Ewormaharg in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2006, 13:03
