Thread: limp mode
    Essex
    confused limp mode
    Hi all, had a problem with my vectra today it's a 2.0 dti 53 plate 46K on the clock, I was doing 70mph on the motorway when it suddenly went into limp mode and a warning spanner appeared on the dash, pulled over and stopped the engine and restarted and all seemed to be OK, also noticed am getting black smoke on heavy acceleration, can anyone give me a few pointers in the right direction. Cheers John
    May 2007
    Hull
    Hi my 20dti went limp and from the forums on here i read that the thin air pipes at the front of the engine bay can split on the connections and one of mine had .. it was the one right at the front just to the right at the top where it joins a kinda sensor thingy .. i cut the split piece out and havent had any more problems .. its worth checking all your pipes for splits mate.. derek
    Essex
    Default limp mode
    Hi thanks for the quick response will check the pipes you mentioned hope its an easy one.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Split boost pipes are common and you should be able to hear it blowing from the engine bay if you get someone else to rev it.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    Quote Originally Posted by dmoffat View Post
    yeah, same here mate...couldn't beleive how easy a fix it was!!!!
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    Definitely sounds like split hose, mine did the same two months ago...just before the EGR valve went!
  1. Limp mode?
    By chrosty in forum Engine & Drivetrain
    Last Post: 18th April 2012, 12:35
  2. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  5. Limp mode
    Last Post: 3rd July 2008, 10:34
