Results 1 to 3 of 3
Thread: Please help, Pedal sensor wire?
    May 2008
    London
    Default Please help, Pedal sensor wire?
    I'm trying to install a tuning chip for my 2.2dti elite.
    It's a hard wire type of installation and I need to locate the pedal sensor wire.
    I know it's in the 48 pin connector located at pin 32.
    The problem is there are no numbers indicating which is pin 32.
    Any help on the colour of the wire, how to read the pins to determine which is pin 32? etc. Anything
    Please help. Thanks
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    take it u mean pin 32 of the main ECU?
    Hertfordshire
    I believe the wire should be near 0v when the throttle is closed, ie off pedal.
    It should then progress up to 5v when you open the throttle up, ie nail it to the floor.
    You should be able to test for this with a multi meter.
  1. right wire for light/rain sensor
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 21:54
  2. Another quick parking sensor wire question
    By aps in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2011, 21:37
  3. Vectra 1.9 cdti 120 Throttle Pedal Sensor
    By brad69bj in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 20:19
  4. Parking sensor - which wire is reverse?
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 22:41
  5. brake pad warning sensor/wire???
    By big rich in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2009, 16:41
