Thread: "Advice please" Difference in shocks between models
    Regular Member Baz07's Avatar
    Lancashire
    Default "Advice please" Difference in shocks between models
    I will be changing my springs to a set of Eibach pro kit ones, and i have been given a full set of SRI shockers..
    My question is that my car is a design model so would fitting the SRI shockers make any difference, are they any stiffer or just keep my original ones with the new springs?
    Jul 2006
    Can never remember.... I think the Vec Design dosn't already have the uprated dampers, so as long as they've come off an SRi with the same bodyshape and engine size, you'll be fine
    The Vectra Design has the normal (non-SRi) suspension. Only the SRi (with respect to the facelift) was fitted with the sports suspension as standard (unless the car was factory specced with 18/19" wheels in which case it would have sports suspension.
    So if yours came with 17" wheels as standard then you'll have normal suspension so the SRi dampers will be worth fitting.
    Just as the others nhave said Baz and seeing as they have done less mileage than yours then i will pop it all on when i do the springs for ya Buddy !!!!!!
    Lancashire
    Thinking on the lines of the weight they were from a 1.9d SRI so not sure now..as mines a 1.8 petrol which shows as 100kg lighter in the technical data part of the book
    Checked the labels on mine to compare and they say the same on the fronts but odviously the inserts would be different
    Here, there and every where!
    Quote Originally Posted by Drinky View Post
    I'll call in tomorrow with your clamps m8
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Engine "models"
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2010, 20:47
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. Advice for first time "mature" skier
    By SignumPhil in forum General Chat
    Last Post: 10th January 2008, 22:03
  5. Replies: 7
    Last Post: 22nd May 2007, 23:14
