Results 1 to 10 of 16
Thread: 2.0T Cambelt Replacement Schedule
    South east
    Default 2.0T Cambelt Replacement Schedule
    Hi, anyone know how frequently the timing belt needs to be changed on an '04 2.0T Signum - don't suppose it's chain-driven by any chance...?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    I'm 99% sure it' a chain.
    I'm 100% sure it's a chain!
    The chain doesn't have a servicing schedule - it should last the life of the engine as long as you give it regular oil changes with quality oil.
    South east
    Exactly what I was hoping to hear! lol. I'm changing from an Omega 2.5 V6 and after changing the belt on that once I don't mind never seeing a cambelt ever again. With a longitudinally-mounted engine, everything is a ****** to access on the V6 Omegas, except the cambelt which is in front of the engine instead of the side, so it's supposed to be a (relatively) easy job. Easy my a$$....lol !
    Mileage : 000
    Mind you they don,t go one for ever. Darn site longer than a belt though.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    definitely a chain my friend getting mine done on Friday....ps my car as only done 20k but chain rattles like hell when labouring ...seems a bit of a problem with that type of engine ...i had tensioner changed 4 months back but still rattling
    Tyneside
    How much is that costing? Would be interested in the pricing of the chain kit alone as I'd rather change mine just for the sake of knowing.
    Quote Originally Posted by signumboy View Post
    First I've heard of that problem in the 2.0T. Are you sure it's the timing chain that has an issue? Was it definitely the timing chain tensioners you had changed?, it wasn't maybe the tensioner on the multi-v belt you had done, the belt that you can see in the engine bay that wraps around the alternator, water pum and AC compressor? - as that is a common problem on the 2.0T.
    You certainly shouldn't be needing new timing chains or tensioners at 20K!
    Mark, you really don't need to be changing these until you've put some serious mileage on the car. They don't have a servicing schedule at all and so shouldn't need replaced at all, certainly not until you've clocked up a hefty mileage - especially if you've been having regular oil changes.
    Tyneside
    Just one of those things thats in the back of my mind Duncan especially with the old 2.2 throwing chains for fun. They obviously learnt a lot and I know it will probably be OK, but just one of those things thats always on my mind.
    When you say hefty mileage, how much are we talking IYO?
  1. v6 turbo cambelt replacement,how much?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 22:45
  2. 1.9CDTi 150 Cambelt Replacement - Big Problems
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 12:48
  3. Cambelt Replacement.....
    By signum_1.9 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2009, 18:33
  4. 3.2 vectra cambelt replacement
    By brickit10 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 22:49
  5. 1.8 cambelt replacement?
    By bloodworm in forum Engine & Drivetrain
    Last Post: 31st December 2008, 20:28
