Thread: warning lights
    Regular Member blackbeauty's Avatar
    Feb 2007
    Benfleet, essex
    Default warning lights
    hello
    can anyone tell me if there is a link where i can find out what all the warning lights mean.
    one has come up on my dash.
    many thanks
    Give us a description of it buddy i am sure we can tell you what it is !!!!
    Feb 2007
    Benfleet, essex
    think its the brakes or clutch
    something flashing with an exclamation mark then a circle with broken lines on the outside
    hope this makes sense
    Feb 2007
    Benfleet, essex
    anyone
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Just looked in the User Manual. Front Brake Pad Wear Indicator - pads down to 3mm?Only on pre-facelift only IIRC
    Is it amongst these?
    Attachment 10032
    Hope this helps.
    Edit: Could also be Brake/Clutch System warning light which would indicate your handbrake is applied (unlikely) although it can come on if your handbrake is off due to a fault with the sensor, or low brake/clutch fluid levels.
    That's your Driver Diagnotic display, that is in the Rev Counter
    If it is flashing, then that would be the brake fluid
    If it staying on, then it will be the front brake pads
    Feb 2007
    Benfleet, essex
    they alternate,
    fisrt its the exclamation in like a bottle and then its the circle, then back and to constantly
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Quote Originally Posted by blackbeauty View Post
    they alternate,
    Tyre pressure monitoring system?
    Illuminated red, flashes red, illuminated yellow?
    Or Bulb replacement?
    If you goto Vauxhall's website you can download a handbook in pdf format for free so you can use to look up the warning lights now, and in the future.
  1. warning lights
    By ian 1234 in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:49
  2. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  3. warning lights
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2011, 17:09
  4. warning lights
    By jules in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 22:09
  5. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
