Thread: Any pointers on changing a Bootlid
    Regular Member Kyser143's Avatar
    Bradford
    Default Any pointers on changing a Bootlid
    In my previous thread I mentioned I had won a VXR rear spoiler but only hitch seller wouldnt risk parting it from the boot lid. So he gave me the lid with it attached..now I have it the colour is same so thought I would change the bootlid with mine. (mine has scratches hence the decision).
    A few questions..
    1) would the internal triming from my lid fit the new VXR one as it has none
    2) I want everything to work eg wiper, rear window heater, boot release from remote and itside door panels. Key is not a prob as key hole is blank anyway
    3) does anything need to be tech 2 in etc
    Want to be sure before attempting the job. Any help appreciated cheers
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    It will probably take some time, but you can remove the boot trim, disconnect the wiring from the wiper and rear boot lock solenoid too. There'll probably a cpl of clips attaching the loom to the boot lid leading up to the top near the hinge. Grommet should pop out fairly easy and remove all electrics. Wiper and solenoid unbolt and should be easyish to remove as well.. Oh and they're may be connectors for the heated rear screen too..
    Nothing at all should need tech2'ing. Good luck with it. Any probs ask.
    Bradford
    cheers plasma..will be attempting it today then. will post pics when done...or maybe a how to depending on me not coming into any difficulties..
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    As dean said,
    It's pretty much a case of un plug, move everything to new unit, and plug back in.
    Bradford
    thnx, just a thought as the new bootlid has all the wiring etc...wiper...lock etc...do i need to transfer some of this from my old bootlid anyway..or they can all stay as they are and just plug all into loom where old lid was disconnected
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    just be carefull when you take the rams off as the boot lid will be heavy
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    It all depends on if there are any connectors inside the tailgate which seperate higher up the loom, but you'll find i think its one piece all the way up to and out of the car. Not sure if theres a plug the other side of it, ie in the headlining when it comes into the car though..
  1. need some pointers
    Last Post: 10th June 2010, 22:44
  2. Any pointers to how much these bits are worth?
    By lee866 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 23rd February 2009, 00:35
  3. lowering-views/pointers/help
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 23:58
  4. how your mouse pointers actually work!
    By eug4611 in forum Comedy & Humour
    Last Post: 8th August 2007, 10:25
  5. need a few pointers
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 23:14
