Results 1 to 10 of 13
Thread: Problem
    Regular Member KieronGSI's Avatar
    Apr 2008
    Aylesbury
    StatsVehicle Info
    Default Problem
    I was driving home last night doing whatever leptons that were required and my handbrake light came on as i was braking for a roundabout, i immediatley stopped and turned the car off but when i turned it on again the light had extinguished. The car did this twice but i dont know why, can anyone explain???????????
    Jul 2006
    Mexico
    StatsVehicle Info
    Sounds like low fluid level mate Check it asap! Hth
    Regular Member Nidge's Avatar
    Mar 2007
    West Yorkshire
    StatsVehicle Info
    Yep, sounds like low fluid. Also check your breaklines to see if they are weeping. Getting mine replaced ASAP as there is severe corrosion in places.
    Regards
    Nidge.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    StatsVehicle Info
    sounds like low brakefluid fella so best to get the brakes checked out a.s.a.p as they could be very low
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    StatsVehicle Info
    I had this to me when I got my car, everytime i went round a sharp corner handbrake light would come on.
    Its caused by low brake fluid level (which i believe is connected to the hydraulic clutch system aswell)
    Had mine topped up and no trouble since and light has stayed out.
    Colin.
    Apr 2008
    Aylesbury
    StatsVehicle Info
    Cheers for the replies will get the brake fluid level checked asap!!!!!!!!!!!!! Dont fancy driving without it lol
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    StatsVehicle Info
    what milage has it done? as i was told my gsi needed a brake fluid change every 40k
    Apr 2008
    Aylesbury
    StatsVehicle Info
    Just checked the level and its just below the minimum so will go and get some fluid cheers for the advice guys. I suppose i should check my levels more often i think!!!!!!!!!!!!!!!!!
    Apr 2008
    Aylesbury
    StatsVehicle Info
    104,000 miles i only bought it 4000 miles ago from the old bill.
    Jul 2006
    Mexico
    StatsVehicle Info
    Quote Originally Posted by KieronGSI View Post
    Please do mate
    Good it was the low level and not the level sensor
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
