Thread: Let me pick ur brains. engine prob :)
    Regular Member Craig1985's Avatar
    harwich essex
    Default Let me pick ur brains. engine prob :)
    right..... Little bro has pug 106 on a w reg
    recently had head done plus cam belt to see if this sorted out the problem. it hasnt.
    the problem is ....... When left to idle it coughs and sits at 500 revs n dies? it some times doesnt want to start? when driving seems fine? just when stationary? also had plugs n leads done?
    any suggestions?
    unseated valve? head not done properly (blowing accross 2 cylinders)?
    by the way head wasnt skimmed and they belived no damage?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    i had a 97' polo and it had a carb on it and it sort of did this. i took the carb out and cleaned it and that helped it
    Full Member Big Sig's Avatar
    Why did he have the head and cam belt done? Did it snap?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    have you check the distributer? i had a problem like this in a suzuki and turn out to be this. also try cleaning the fuel injection out with something like reddex see if that makes a difference. another thing could be a blocked exhaust, thats how i killed the suzuki lol
    Birmingham
    I had a similar problem on a Corsa....turned out to be a blocked Cat and then on another Corsa had the exact same problem, on that it turned out to be the crank sensor. I know they are different engines, but most often than not all the same problem usually point towards similar parts.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    they could easily have not connected one of the sockets back properly, or not at all! worth going round to have a check!
    Also, can you not go back to the garage who did the cambelt? Surely if its been since then they should take some ownership of the fault?
    Bye bye Vec B
    - Hello Siggy!
    harwich essex
    Had The Same Prob B4 Changes. Harage And M8 Expected To Be Head Gasket Blowing Accross Cylinders? Tecy At Work Done The Work.
  1. Pick your brains
    By Danger_MouseUK in forum Suspension, Wheels & Brakes
    Last Post: 21st March 2012, 10:37
  2. Help please??? Engine prob
    By sri adi in forum Engine & Drivetrain
    Last Post: 1st July 2010, 19:31
  3. Replies: 8
    Last Post: 10th November 2009, 12:22
  4. Need to pick your brains / spoiler screw problem
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 22:52
  5. Need to pick your brains
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2008, 15:38
