Results 1 to 10 of 16
Thread: PC Problems, driving me round the twist ....
    Default PC Problems, driving me round the twist ....
    Can anyone throw any light on my PC problem ...
    Started just before christmas and I have tried to sort it, but it has beaten me !!!
    When the PC starts up it is normal, but i cannot click on anything, then after a couple of minutes it is OK. When I open the internet the click on either Outlook or Explorer the pc locks up, wont do anything for about 3 minutes then it opens OK. If I bring up the task manager, which takes about 10 seconds to open, it unlocks again. I then have to do the same for Explorer, then everything runs fine.
    I have uninstalled evrything which I have installed since the problem started. I have tried system restore ? I have checked all my Antivirus settings which are all OK. The database is up to date and I have done scans, no virus found (I run AVG 7 Profesional, not the freebie version) I have run Adaware, stinger, spybot etc and nothing found ..
    Also had a look in the registry and nothing odd there, could it be a memory problem, as in faulty, I have 768k ? Also I have all the windows updates in including SP 1&2 ...
    It is doing my head in !!!!!! Don`t want to admit defeat but think I have to ....
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    we had a similar problem last year, turned out to be spyware..have you tried spysweeper by webroot its very good plus we had no probs since installing it. the web addy is http://www.webroot.com cheers, Bob.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Or go and get Microsoft's anti-spyware, which is free, amazingly, and not half bad!
    Phil
    Regular Member Tim2100's Avatar
    Walsall
    Sounds like the computer needs a rebuild.
    Back up your data
    Format your harddrive
    Reinstall Windows!
    Quote Originally Posted by Tim2100
    Back up your data
    Reinstall Windows!
    Thats what I am trying to avoid !, I think I might have to bite the bullet though. I am on dialup and updating windows takes hours ..
    Walsall
    I know I need to rebuild mine soon. I keep putting it off. but When I do I will use some imaging software which will make it much easier. Most PC's do need to be rebuilt & cleared off every now & again.
    Why you still on Dial-up?
    There are lots of good deals on Broadband now!! I have just signed up to 1mb broadband (Line can only take 1MB) unlimited downloads for £10 a month! A lot better than the £30 I was paying BT!!
    Wiltshire
    Try ctrl/alt+del and look at the processes that are running. Then use the link below to see if any of them are rogue ones. Any you can't find on there, just type into google and see if they're valid processes or not.
    http://www.tasklist.org/
    Don`t get me started, I was on a commitee in Cove, where i live, to get broadband here as we were not enebled. we were succesful in getting enabled after a lot of campaigning. I ordered mine up and nothing. Too far from the exchange.... After a year extended reach was annonced, and I could get it, so i ordered it and again it didn`t work, Engineer came out tested everything, no problem with the house . I live in a circle and the cable is damaged. As it can carry a voice call, which is all BT are contracted to do, they won`t fix it so no one in the circle can get broadband.
    So I am stuck with poxy dial up .....
    Wink
    Try going to http://www.symantec.com/avcenter/global/index.html , go to bottom of page and click on security check (nortons) and look for free online scan, because this is the only free online spyware scanner and anti-virus checker, that checks the restore folder.
    Tommy - bite the bullet mate and rebuild. Don't use any imaging software as what's causing the problem could/will be transferred to your new image. Just backup any data you need to a storage device (CD/DVD/USB) and format your drive/s then install everything again. You sound like you know what you're doing anyway.
    As it's been said, PC's need a rebuild every now and again, so it's time for yours now. I know it's a ball ache but it's better than going round in circles (as you've already been doing by the sound of it).
  1. B4 all round or B6 all round? Advice Please.
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2011, 19:39
  2. Police Opel 2.8 driving round Leeds
    By Ziggy in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 2nd February 2010, 16:55
  3. A twist to the V
    By Knight Rider in forum Styling
    Last Post: 25th May 2009, 16:43
  4. Slight twist on the VXR rim.
    By rushy in forum Styling
    Last Post: 29th December 2006, 01:19
  5. skipping with a twist !!!!!!!
    By Drinky in forum Comedy & Humour
    Last Post: 10th October 2005, 20:16
