Thread: Indicators not automatically cancelling
    Harlow
    Default Indicators not automatically cancelling
    I have just bought a 53 plate Vectra-C 2.2i Elite. The indicators don't cancel after turning the wheel and I have to manually cancel by just touching the stalk.
    There is another problem where cruise control isn't working. The book says I should see the symbol for it light up on the instrument panel when I start the engine, but I don't.
    Although these two are operated on the same stalk I don't know if they are related or not.
    Suggestions?
    It could be the stalk I guess, Not sure on the indicators, but the clutch pedal has a spring that is a common fault. Try lifting the clutch pedal and then turn on the CC. Remember you should need to have touched the brakes at least once before it will turn on.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Thnk there is also 1 or 2 dodgy indicator stalks, aslo try lifting the brake pedal
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Worst case could be the CIM.
    11 Post(s)
    Quote Originally Posted by 5ft10ins View Post
    The handbook is wrong. I've yet to see a Vectra-C cruise control light come on as a check light with the ignition.
    Harlow
    Sorry, should have said this is an automatic.
    Quote Originally Posted by Gr4eme View Post
    It could also be the brake pedal. Although a new stalk isn't expensive.
    Harlow
    It was the stalk. Had it replaced and now the indicators and cruise control operate as they should. Thread closed.
  1. Indicators not self-cancelling
    By john_k_sri in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2013, 18:01
  2. Upgraded Radio won't turn off automatically?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2010, 19:40
  3. Radio comes on automatically when switching on ignition....
    By waterbourne in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 22:19
  4. How to set the clock automatically on CDR2005...
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2009, 23:42
any problems with insignia indicators not cancelling
vauxhall cim recall non cancelling indicators
