Results 1 to 10 of 20
Thread: Outside Temperature Sensor
    Regular Member Finty's Avatar
    Jan 2006
    Ireland
    Default Outside Temperature Sensor
    Hi
    I'm new here so I'll firstly say hello to everyone!
    Anyway the outside temperature sensor on my Vectra seems to have a problem i.e its constantly reading about 6 degrees higher than it should be. I've tried cleaning the sensor but no luck. Does anyone know the part number for the sensor and if its a tricky job to fit it
    Finty
    Welcome mate. Enjoy.
    Someone will be along shortly with that part number for you bud.
    Nr Cardiff
    Hello and welcome mate.
    Dec 2005
    In the sponge-monkey tent
    Hi Finty, welcome to the site.
    I had similar trouble with the sensor in an astra after a service. Took it back and they re-callibrated it, worked fine after that.
    Jan 2006
    Ireland
    Thanks for the welcome. Had a quick browse around and its a great site
    Thanks Spikey.....it does sound like a calibration problem and coincidentally its just had a service....****** electricals always giving grief!
    Mileage : 000
    hi welcome to the site, has the warrenty run out on your car, they may put it right under the three year warrenty.
    Jan 2006
    Ireland
    over here in opel land they only give a 2 year warranty so unfortunatley thats run out
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Welcome aboard Finty. eace:
    Welcome Finty - The sensor is to be found behide the front bumber, simply unplugs - very easy to change. OPen the bonnet and look central down towards the bottom of the rad. The little black plug is the sensor. Hope you get sorted
    Jan 2006
    Ireland
    excellent sounds easy to change...just need the part number now....could only find the Vectra B part number online
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  3. Outside Temperature Sensor
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2008, 10:59
  4. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
  5. Outside Temperature Sensor U/s
    By turnerk in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 22:05
