Results 1 to 10 of 11
Thread: A little info required
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Thumbs up A little info required
    Im looking to replace the standard cd30 in my vectra to get one of those new double din thingys.
    This is where i need your help/input
    I believe that i need a additonal cable to use the steering wheel control?
    Do i need any other cables?
    Other posts i have read say you may need a facia plate as well? Do you?
    Will i lose the display screen functions? Mpg radio and time?
    If there any thing specifc i should be looking for when buying a double din unit?
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Its pay day tomorrow any thoughts
    May 2008
    St.Albans
    Quote Originally Posted by phil67 View Post
    Would love to know that too, but I think nobody on here can answer it
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes
    yes a adaptor (either from new canbus facra, or the "old" depending on car)
    yes you do need a facia plate
    you will lose radio and problaly time. BC will work.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Thanks kenp, might have to do a bit of spending now!
    May 2008
    St.Albans
    Thanks kenp
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Yes, you will need one to use steering wheel controls
    Yes, the main ISO adaptor, this will be a "plug & play" item.
    Yes, You'll need a facia surround, You can get the same colour as your dash. It just fills the gap and helps support the new unit.
    No, your computer (Mileage, MPG etc), and clock will still remain. As for the radio names, I know with Kenwood Units you can get an adaptor to put the radio text on the display. But if like mine, the date will be displayed when the unit is off, and will either go blank or stay on when you switch the unit on
    Here, there and every where!
    A lot depends on which head unit you buy. Some are supported by the wheel controls and others aren't. Bigger names such as Alpine, JVC, Kenwood etc are ok and the leads are available for them.
    Try a few audio specialist sites.
    http://www.caraudiocentre.co.uk/
    http://www.caraudiodirect.co.uk/?k=c...=Google&p=0.21
    http://caraudiosecurity.com/shop/home.html
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Thanks everybody
    May 2008
    St.Albans
    Pioneer adaptor lead is around £30 I believe...
  1. GM MDI and TECH2 info required
    By Mike1.9CDTI in forum General Motoring Chat
    Last Post: 13th February 2013, 14:14
  2. INFO - required please vec 2.0T
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 10:11
  3. GSI info required please
    By falco in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 06:06
  4. INFO Urgently Required!!!
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2008, 11:21
  5. T I S info required
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 22:07
