Results 1 to 10 of 15
Thread: Help!!
    Regular Member pinoy's Avatar
    newport,gwent
    Default Help!!
    hi guys, i have got a vauxhall vectra c.but since last week my screen (inside the speedometer clock area)keep showing a steering wheel sign on it everytime i switch the engine on.it goes off after few seconds and goes back now and again everytime i have to accelerate the engine or sometime if im driving going up the hills? is it a major problem? is my car still safe to drive?
    6 Post(s)
    The light is indicating there is a problem with the electric power steering. Needs plugging into a code reader to find out why.
    As to whether your car is safe to drive, if the PAS fails, the steering will become heavy all of a sudden - which could catch you unawares depending on whatever it is you're doing at the time.
    Sounds like it might need a touch of oil in it but be aware there are two types of oil one is standard "red" power steering oil the other is a mineral "green" oil make sure you use the right one !!!!!
    newport,gwent
    thanks guys, the problem is i went to halfords to get some oil for it ,thinking it s needs topping up but the we couldn't find any place to put oil in it? the man said to me that my steering wheel might be electric?(my car,vectra c sxi 2002)
    Full Member Big Sig's Avatar
    its electrohydraulic. It does need oil. I think its at the back somewhere in a small bottle with a black top.
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    where exactly is the bottle??? Does it say anything on the cap??
    Actually, I may have been wrong, I have just had a look at mine and cannot find the bottle either!
    Oct 2006
    Lisburn, NI
    I have had a look and there is a bottle below the drivers side headlight. I cannot even get my hand in never check fluid levels!!!! Think we need Gsi3.2's help
    Regular Member simac's Avatar
    Wirral
    Being an 02 plate, the fluid container is likely to be down behind the engine on the rack, it's a white bottle with a black cap. Similar size to a 1 litre oil top up bottle.
    You'll need a funnel with a long pipe on it, there is a dip stick on the container's cap. You can get the funnel and pipe from Halfords for a few quid.
    HTH
    Oct 2006
    Lisburn, NI
    Hi, i've just looked at mine and cannot see it there. The only thing i can see is the bottle under the headlight. Can you shed any light on this mate?? Thx
