Thread: Estate headlight and rear window washer problem
    Regular Member henryf's Avatar
    Oct 2007
    Hollola / Finland
    Default Estate headlight and rear window washer problem
    My car is -07 estate. I recently updated new headlight switch and i just wondering is it possible that will make also this problem. I visit (2,5hours) at the dealer and they said that engine fuse box should be replace there could be something +700€ + work, outch. At the junk yard i will find it for 150€.
    When i put ignition on and start engine these washers will work couple of seconds but not after that. Restart will reset the problem again for a couple of seconds.
    Anybody familar with this kind of problem.
    Oct 2007
    Hollola / Finland
    I don't have a washer fluid level indication. Should i test it?
    About 5 months ago i updated headlight switch with auto position (+ tech2 treatment) and quite soon i noticed this washer problem.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I'm not sure if I understood your question...
    ... you installed ALC (auto-lights) and now you have trouble with the headlamp washers... is this right?
    If the washer fluid level is almost empty, the headlamp washers won't work properly, but the windscreen still does... So, try first to fill the washer bottle
    Oct 2007
    Hollola / Finland
    Noup
    I just installed headlight switch with Auto position and now there is 4 positions. Auto, 0, park lights, and driving lights.
    Washer fluid tank is full and i don't have a sensor in tank.
    Oct 2007
    Hollola / Finland
    They have been hassle with Tech 2. Now i have rain sensor and all washers are working perfectly.
  1. Rear window washer
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 23:00
  2. headlight washer problem
    By ditchp in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2010, 22:06
  3. water bottle for rear window washer
    By hovis007 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 12:38
  4. window washer problem
    By patrick1062 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2008, 17:47
  5. Rear Window Washer?
    By PTC8 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 21:39
vectra c headlights switch repair
