Thread: Signum Lowering Springs
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Signum Lowering Springs
    I am after a set of signum lowering springs but am having trouble working out which ones will fit my Signum 2.2dti
    What have you guys got? I've looked at LMF and they have a good selection but i can't work out which will be the correct ones
    Please help
    www.roadrunnermotorsport.co.uk
    look in the OPEL section to see what kit you need, the selection is more comprehensive the lmf's..
    Signum 1.8, 2.0 Turbo, 2.2, 3.2, 2.2 DTi 03.03 - 1060 kg 1140 kg 10-65-011-01-22 £138.00
    Signum 2.0 Turbo, 3.2, 2.0 DTI, 2.2 DTi 03.03 - 1130 kg 1140 kg 10-65-011-02-22 £138.00
    so it appears that all you need is the info off your chassis plate for the front axle weight and you'll know which kit you need..
    1130kg means 10-65-011-02-22
    1060kg means 10-65-011-01-22
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Check the axle weights on the drivers side door pillar, and this will tell you the springs that you will need. Fitted Eibach -30mm to mine (1.9CDTi) and I think the final numbers on the part number were 002.
    Wayne
    Devon
    Engine : 2.0 Turbo
    wow that was quick, Thanks Mark and Wayne :Thumb: i'll check in the morning
    How much will they cost to fit?
    any garage could do them in an hour and a half..... my 'record' is currently 30 mins ( but thats with air tools. )
    Devon
    Engine : 2.0 Turbo
    and where is you legendary workshop I will let you fit them so so can try and break your record haha
  1. lowering springs for signum
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 20:25
  2. signum lowering springs???
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 07:33
  3. Signum Lowering Springs
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2008, 18:02
