Results 1 to 10 of 15
Thread: CDR2005 power button
    Stafford
    Default CDR2005 power button
    The power button on my radio (CDR2005) no longer seems to work unless it receives a hard shove. Is this a know issue? (I've tried searching... honest). If so is there a fix? Thanks.
    southampton
    mine is exactly the same, has been since i got the car last year, mine is the same model i think but not sure
    Ipswich
    Hi, I have the same problem. Mine has now got a bit worse, when you turn the volume up or down, sometimes it works the opposite way, i.e. volume goes up, when you want it to go down and vice versa. I have spoke to a radio repairer, who said it may be a board inside that's gone, but frankly I think it is simply the switch, because, if you put pressure on the switch at the top or bottom, it works ok.
    I am going to take the radio out and have a closer look. It may be difficult to (A) get a new switch or (B) get to it to replace.
    The alternative is to look on Ebay for a replacement or the breakers, who will charge around £90.00 secondhand, buy another radio, but lose some of the functions and perhaps looks or live with it until it completely gives up the ghost.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sunny Dartmoor
    Spray some WD40 in the button and turn it a few revolutions,could just be dirty.......
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It would be better to use elctrical contact cleaner, as it washes any dirt out and dries completely with no residue.
    Sunny Dartmoor
    Quote Originally Posted by Ste View Post
    Thats what i've been told to use in the past,does a very similar job.....
    Stafford
    rolleyes
    I tried contact cleaner and it helped but didn't cure. I even dismantled the radio to see if I could get fluid right into the switch. Unfortunately the switch body is a really tight fit onto the spindle so it's difficult to get much fluid in. At least the button is now intermittent rather than non-existent .
    While I had the radio in bits, I added an aux-in socket as per this website (http://www.css-haupt.de/vectra/english.html). It works really well on mine but I didn't mind if I killed the radio in the process so if you're thinking about doing likewise proceed with caution!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The fitting of a stereo input sounds a great idea. I might do that..
    Just wondering how to create a full CD of silence....
    Sunny Dartmoor
    Does state how to do it in the how2,sounds a good idea........
    Nice one ray,great mod,you may have started a trent for us CDR-2005 owners............
  1. Boot Button vs Lock Button
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2013, 21:30
  2. sport button, traction control button
    By Denbro in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 23:44
  3. Audio Power Button
    By T786 in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2011, 21:26
  4. Cdr2005
    By kinger in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2006, 09:33
replacement cdr2005
cdr 2005 volume switch
cdr 2005 on off button
volume knop cd2005
cdr 2005 power button
power button vdo 2005 radio
radio cdr 2005 power off doesnt work
VDO 2005 bekapcsoló gomb
cdr 2005 volume button type
cdr 2005 volume button repair
cdr 2005 on button
vauxhall cdr 2005 car radio no power
av på knapp cdr 2005 vdo
cdr 500 power button not working
how to fix cdr 500 power button
siemens vdo cdr 2005 switch
vdo volume button opel
purchasing a on switch cdr2005
