Thread: steering warning lights
    wrexham
    Default steering warning lights
    Hi all, got myself a 2ltr vectra dti on a 52 plate, steering warning light comes on when i put my foot down(especially round corners, more so accelarating up hill), the steering doesnt seem to fail, just wondered if anyone had any input??? Also, when i start it in the mornings, the spanner light(not the service light) comes on for 30 secs or so, can someone shed any light on this, many thanks
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    need to check the fluid level on the pump which is located behind the front bumper under the drivers head light hope this helps
    and to vectra-c.........
    Birmingham
    Quote Originally Posted by geraint2112 View Post
    Spanner light....needs to go on a Tech2 if it comes on on every startup. Mine did the same, then after about 40 fresh starts the spanner light never came back, still took it to Vx to have it tested and it never showed anything so got lucky, but def get it tested!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member simac's Avatar
    Wirral
    On a 52 plate the fluid reservior will be on the rack down behind the engine, it's a white container with a black lid. The lid has a dip stick attached to it.
    I think only the later cars have the gubbins behind the headlight
    Birmingham
    Bye bye Vec B
    - Hello Siggy!
    Wirral
    Makes perfect sense to me
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by simac View Post
    Think it's engine-specific. In my old '53' 1.8 it was behind the engine, in my current 2.0T it is underneath near the front driver's side headlight.
    Jul 2011
    Newport
    Today my Vauxhall Vectra 52 reg 2.0 DTI showed a warning light of a car with spanner on it,wat does it mean any help out there
    Full Member
    Bristol
    Quote Originally Posted by Bhekie71 View Post
    It means its flaged up a fault you need to get the ecu read to see what code it is causing the problem.
  1. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  2. warning lights
    By ian 1234 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 20:34
  3. Lots of warning lights + loss of power steering
    By Sparky67 in forum Troubleshooting
    Last Post: 29th March 2012, 10:38
  4. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  5. warning lights
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2011, 23:50
