Thread: swirl valve info please
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Default swirl valve info please
    hi guys, due to my recent probs with swirl valve and me not having a clue what that is and what it does.
    i was just wandering if any one would be able to tell me, what it does?
    where it is on the car (i know it in manifold but if i look at the engine can i see it(a photo would be brill)?
    also are all the new replacements bigger like someone previously mentioned or are there different sizes.
    i know this is all a big ask but could do with knowing so when job is done i know what i am looking for incase i get fobbed off.
    once again big big thanks
    martin.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There was a thread recently with some good photo's
    The swirl valve basically opens the second inlet port at higher engine powers to make the air entering mix with the injected fuel better (the swirling effect of the air continues through the compression stroke and when the fuel is finally injected). When the engine is at relatively low speeds and loads, the valve is closed, so air only enters the cylinders via one inlet port. This increases low end torque. When it opens it allows both ports to be open, thus allowing easier air entry and greater swirl values of the air.
    Nov 2007
    telford,
    aaaaagh i see. any one else know any answers to the other questions?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its part of the Inlet manifold (big black box in front of the engine)
    they have to change the manifold completly to change that walv.
    Oct 2006
    southampton
    15 Post(s)
    mines going back to dealer next saturday to have one fitted under warranty. the cars a 55 plate sri with 9700 on clock, they said that was part of the problem as the engine not worn in completely.
  1. Some great info here on swirl flap issue.
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 02:31
  2. Swirl valve bar off....
    By johnnyboy1985 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:04
  3. Egr valve, swirl valve problems etc..
  4. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  5. swirl valve
    By d2sds in forum Petrol Engine related
    Last Post: 5th December 2007, 21:42
