Thread: Pinking???
    Tyneside
    Default Pinking???
    Is there anyway I can tell for definate if the engines is pinking? Starting to really worry about this and whether I've started the process of f00king my engine with this exhaust.
    Just for those that don't know the exhaust BSR provide is 2.5" from the cat back and mine is 3" from the cat back to the y-section and 2.5" to the tips. Can anyone with a good knowledge of engines/exhausts give me some info on this please.
    [Ex]Admin Duncan's Avatar
    You're not going to get pinking due to the different exhaust Mark. Pinking is a combustion related issue i.e. fuelling and air/fuel ratios
    http://en.wikipedia.org/wiki/Engine_knocking will help.
    Full Member Big Sig's Avatar
    You would hear it when driving. Do you use high octane fuel or standard unleaded? Maybe run SUL for a while to see if it makes a difference. It could be possible your getting a bit of detonation, sul would help this.
    Ashington, Northumberland
    Pinking wouldn't occur anyway because of the action of the knock sensor. It detects pinking and tells the ECU to retard ignition to eradicate it.
    Tyneside
    Cheers guys Was BSR that mentioned it when I asked about the exhaust and instantly the panick button was hit then I thought I heard a noise when it was ticking over, but that was obviously the squeaky pulley.
    Always use SUL, alwyas have since I got the car and have to with stage 3.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    will be glad when you get this all sorted Mark.........is a real shame you cant make the RR day
    Tyneside
    It would have been perfect to really tell what the cars doing, but not to be sadly. Although if Duncan makes it I can at least take some info from that and I hope you get the expected figures this time Ian.
  1. pinking
    By speedfreeride@yahoo in forum Engine & Drivetrain
    Last Post: 21st February 2011, 00:04
  2. Not a Vectra but my wifes Astra is pinking
    By spatch in forum Engine & Drivetrain
    Last Post: 20th February 2011, 23:59
  3. 150cdti pinking noise?
    By conny in forum Engine & Drivetrain
    Last Post: 19th August 2009, 18:32
  4. pinking problems?? advice please
    By dhallett1 in forum Engine & Drivetrain
    Last Post: 9th May 2009, 22:33
  5. Pinking and judder
    By Martyn21 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st November 2006, 04:03
