Thread: Handbrake cable
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default Handbrake cable
    Can anyone tell me how to access my handbrake cable at handbrake end
    yep, it's under the rear centre armrest /tray... work from the back seats..
    remove the cover around the rear lighter socket.. remove it's wires..
    remove the ashtray carrier plate, this will reveal 4 torx screws..take them out..
    remove centre arm rest backwards into the rear footwell..
    you now have access to the front ends of the cables and the balance bar....
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks will try this tonight after work , my handbrake is only holding on one side but is attached at disc end
    could just be a seized rear quadrant on the caliper as well..... if you can see the cable moving ( trying to apply the pressure) on the bad side of the car but the quadrant isn't moving then it's prob seized.. if the cable moves and the quadrant does as well, but still no effective handbrake then it's either a seized piston ( try winding it back in and pushing it out with the footbrake) or a stuck pad (strip and refit with coppergrease after cleaning the pad rests right up)..
    happy hunting..
  1. handbrake cable
    By mbtech01 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2013, 16:47
  2. caliper & handbrake cable
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2010, 17:19
  3. handbrake cable
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 12:49
  4. Adjusting the handbrake cable?
    By jamesr in forum Suspension, Wheels & Brakes
    Last Post: 6th February 2007, 00:03
