Results 1 to 10 of 11
Thread: 2.2dti or 2.2direct petrol
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    Default 2.2dti or 2.2direct petrol
    hi guys at the mo i have a 54reg 2.2 direct sri vectra but i'm seriously getting the 2.2dti due to tax and running costs. just wanted to know which engine is more reliable as i have only had the current vec for 6 months.also what are the common faults of the 2.2dti.
    once again thank you guys
    martin.
    Feb 2007
    North west
    I had a 2.2 dti for 3 years with no issues. Rubbing noise from steering was the only issue, wd40 only solved it for a day or 2. Silicone lubricant sorted it once and for all. Otherwise faultless. A lot less go than a cdti or 2.2 petrol, hard to tune (expensive) and get about 145 bhp if you use tunit (£500). Economical though. 2.2 petrols are a popular choice, whats the tax like on them ??
    boost sensor failure ( limp home mode)
    split boost hoses ( as above)
    injector seals fail, leak off pipes perish, rubber fragile fuel pump, turbo seals fail...
    of the two, if I was buying, i'd stick with the Direct...all that is known for is the high pressure pump and swirl valves failing...
    with the price of petrol and diesel, and the rate of faiulure of the two engines, i'd not be swapping..
    Nr Cardiff
    After my experience with the Dti I wouldn't go near one ever again. Stick with the petrol.
    Nov 2007
    telford,
    on that note i think ill stick with the direct.cheers fella's
    Nicking Ya Dinner.
    Ah hang it mate, get a 3.2 V6 and put a big poster in the back window saying "up yours Darling"
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Had my vec for 3 years now. Had a few problems bottom pulley broke off common problem. Rear shocks failed common problem. Other than that very very happy with it. Exremely economical 60 mpg on motorway low 50 mpg A roads.
    Very power ful good for my caravan. I would recommend them to anyone.
    Larkhall
    My 2.2 DTi Auto got from Scotland to PVS and back on a full tank which i thought was very good
    The pulley broke a few months ago but other than that i've had no other major problems. The Limp Home Mode happens occasionally though.......
    My previous Veccy C was a 2.2 direct, and tbh i think the DTi runs much smoother
    Regular Member Small Racer's Avatar
    Jan 2008
    Hampshire
    Go for the petrol 2.2 direct - the gas & diesel price now negates the capital expense of the diesel unless you are doing about 110 miles a day every day!!
    But each to his own. - I had diesels for donkeys years and now I am back in a petrol the differance is wonderful
    Nov 2007
    telford,
    like i say i already have a 2.2direct petrol but with tax on the 2.2dti being cheaper i just thought it might be worth a look but the 2.2dti seems a bit to much hassel for me.
  1. Bye Bye 2.2Direct
    By Discreet in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2012, 21:33
  2. 2.2direct gearbox
    By vec22direct in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 17:35
  3. Think my 2.2direct likes a drink of petrol!!!!!
    By Sheldon in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 22:12
  4. My SRi 2.2Direct
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2009, 14:44
  5. Petrol in deisel 2.2dti now won't run - help!!
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 19th July 2008, 11:00
