Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: veggi oil
    May 2008
    fife
    Default veggi oil
    i have a 2.0 dti 52 plate vectra c will this run on veggi oil
    Full Member Big Sig's Avatar
    Yes i think the dti's are ok on it, but ont the cdti's
    May 2008
    fife
    have you any idea of the mix
    No sorry, no idea. I did read about someone who used 75:25 veg oil to diesel in an old fiesta in the summer and the other way round in the winter.
    They will run on it but just a word of warning put a fresh fuel filter in as soon as you start using it and ALWAYS change it every 10,000 miles as the veggie mix will pick up all the crud from the bottom of your tank and block the filter very quickly indeed .........Not sure on the mix but i am trying to find out !!!!!
    East Midlands
    Quote Originally Posted by stj View Post
    Not advisable m8,in relation to the fuel pump on the 2.0dti,it needs proper lube from diesel,as i have researched it elsewhere,and if you knacker your pump...er it's an arm and two legs to replace,i myself will not be risking it.
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    not an arm and two legs.... more like four legs.
    They retail around £1200 and then labour!!!
    Birmingham
    Quote Originally Posted by macdad View Post
    Totally agree, cost of fuel is high, but will knacker your car!
    Bye bye Vec B
    - Hello Siggy!
    it's not okay to run it on 100% veg oil...BUT as drinky said.. ... if you blend it with DERV the pump will survive..
    do as he advises.. and keep the fuel filter changed and don't go beyond 60-75% veg oil to derv.. ideally 50-50 mix...
    in the winter just use nearer 90% DERV and 10% oil..
    uk
    I am fitting a 2 tank mod to my 2004 2.0L dti vectra. I will let you know how it goes. Easier on the ip because it starts on diesel and finishes on it too, and runs on veg when its up to temperature.
    JTG
