Thread: Electric windows via Key fob
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Default Electric windows via Key fob
    Any idea's on this little problem,. I used to be able to open/close my windows via the key fob on my Veccy, hold the open button on the fob and the windows would open, and like wise , hold the lock button down and the car will lock and shut the windows and then deadlock the car,
    Well now I can still shut the windows and lock the car, but on both key fobs I can't open the windows via the key,
    Has anyone had the same problem or any one know of a fix, when I 1st got the car it used to work, -- have I changed a settting or something ?
    Cheers in advance, mark
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    funny you should say that, mine has gone exactly the same way! Will close if held in but will not open the windows. Difference is though i've had programming work done to enable the folding mirrors, will try to dig into this problem at some point and see whats going on.
    Oct 2006
    Portsmouth
    Funny you should say that, I spoke to someone today who say they had the same problem on a mini, the had to have it re-enabled on the ECU after having some folding mirrors fitted,
    I twigged when he said that , I've had some ECU work so it could be a Tech2 jobbie ,
    Let me know how you get on
    Jul 2006
    Mexico
    Does the interior switch One Touch feature works? on both of your cases?
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Yep.
    Jul 2006
    Mexico
    Quote Originally Posted by plasma View Post
    Yep.
    Well that dismantled my theory
    My best guess is that feature has to be Teched2 again.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    thanks for that
    did not know it did that, tried it and it works!
    cheers lads
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Quote Originally Posted by markm View Post
    Is it a 57 plate or newer? If so, the opening of the windows no longer works. But you can close them with the key fob. I had this issue with VX when i bought mine - it's not an option on the newer models (57 and onwards) Have a look in the manual and if it's a newer model, there will be no option for opening the windows, only closing them
    Edit, just read your email correctly now! It USED to work, but now doesn't...I say what your saying.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if it is a early car if the remote batt is slightly flatt the cim will sense it and not work the windows as to not flatten the remote battery totaly try a new remote batt unless its a 57 plate onwards
    May 2006
    Nottingham
    Works on my 57 Signum, but lets see what happens after the next service...
    Andy
  1. electric windows help
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 17:37
  2. Electric windows
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 20:10
  3. electric windows
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2009, 10:34
  4. electric windows
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2009, 21:48
  5. electric windows
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2008, 18:15
key programming opel vectra c windows
vectra c windows go up with fob but not down
vectra c windows up on key fob
vectra c open windows on key function
how to restart my vectra fob for a window
vectra c windows open
electric fobs ellesmere port
vauxhall vectra i can close my windows with my key fob but cant open
how to get automatic windows working of key for signumc
vectra windows wontbwork fob
