Results 1 to 10 of 11
Thread: rear spoiler
    Regular Member bish's Avatar
    peterborough cambs :P
    Default rear spoiler
    Hi all, just fitted my rear irmy spoiler, but the middle support on the spoiler does not touch my boot lid???? theres a 4 or 5mm gap
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    it should as mine is a tight fit on the car....
    Irmscher supply some bonding gue to hold it down, but i drilled the bootlid on mine and screwed the centre leg down as well..... rock solid..
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    is the top bowed then ??? just get someone to sit on it while you glue it .............only joking
    job for my dad..
    cheers guys, you reckon tiger seal will hold it
    if you score the bootlid to give it a good key first then it might... i had to resort to the screws thou as it kept lifting..
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Mark.
    How quickly does the Irmscher Bonding Go Off ?? & Does it stick like Sh!t to a Blanket ? is it a Type of Contact Adhesive ? As i have my Estate spoiler to Fit when im feeling Brave Enough
    Dean
    the irmy bonding is supposed to be 24hrs.. i use silkaflex which goes off even quicker ( about 2 hrs in this heat) and holds better IMO...
    silkaflex sticks VERY well......all the stuff i've ever had come with irmy stuff has already gone off in the packets, so i automatically use silkaflex now...
    it's not a contact adhesive like a glue, it's closer to an adhesive silicone sealer..
    Regular Member D-S-Dave's Avatar
    Jun 2006
    Home init
    He's not wrong, sticks like erm, you know the sticky stuff.
  1. Fitted rear spoiler, rear wiper arm hits it
    By JuzzyD in forum Bodywork & Interior
    Last Post: 9th September 2007, 19:00
