Results 1 to 10 of 19
Thread: Oil from Max to Min in 400 miles - any ideas ?
    Regular Member simac's Avatar
    Wirral
    Default Oil from Max to Min in 400 miles - any ideas ?
    Over the weekend I did almost 400 mway miles and the oil level was on max before I left. When I got home last night I checked the oil with the car parked in the same place and it's a fraction under minimum
    The same thing happened last month when I went to Scotland, I thought I must have made a mistake when reading the oil (parked on a hill etc etc) so this time I made sure I had the car parked in the same place both times.
    It's a 2003 1.8 with 70k miles on it, i've had it since 13k miles and have only had to give it very small top ups between services until now.
    It doesn't smoke on start up, doesn't smoke while driving and doesn't make nasty knocking noises - can't find any leaks either
    All I can think off is perhaps it's blowing past the piston rings due to wear/mileage.
    Any more ideas would be welcome ! if I was more "flush" right now I would think about changing it because i'm worried that my ickle Ecotec is heading for that little place in the sky for VX engines
    1.8's do use oil when pushed hard.. yes you are right, it will be a bit of blowby that has used it...
    DO NOT flush it.. worst thing you can do... you'll just have to keep an eye on the levels a bit more.. has this 'just ' occured or has it been slowly using a bit more, then a bit more between services.. also, how often do you service it and what oil do you use?
    Wirral
    Thanks for your reply Mark
    It's had annual services at the dealer and they have been using Shell Helix Plus 10-40 which I have been topping it up with. I have used Magnatec when I couldn't get the shell stuff.
    I've just checked the coolant and that is nice and clear, was changed at last service (phew!)
    It's started to use more over a period of time but the last couple of longish runs i've done (with it fully loaded up) it's been an oil-a-holic ! This will be the 2nd litre going in over only 1500 miles.
    If it's just wear and tear i'll just check it more regularly as you suggest, I just hope that it's not thinking of failing big time
    PS: It has been flushed at all services, i've had it since it was a year old. I think the dealer use Fort ?? something ?
    it would have been forte flush..
    if it's been flushed all it's life then it's better than having it's first flush at 70K...
    when you say annual services?.. what sort of mileages is that at?.. as the 10W40 is all 'dead and gone' by 10,000 miles max...
    Wirral
    Normally around 18k a year
    If I was to give it an oil change, is it ok to switch to a different grade after so long and which should I use instead ?
    Have looked in the book today and it says 10-40 can be used if the higher quality can't be obtained but service intervals should be reduced.
    Cheers Mark, your help is appreciated as always !
    11 Post(s)
    Vauxhall's website recommends 5w/30 for all Vectra's registered from 2002 onwards.
    http://www.vauxhall.co.uk/vx/owners/...oils.do#Vectra
    Quote Originally Posted by simac View Post
    you mustn't go any further than 10-12,000 on 10W40 oil.. irrespective of what the book says..
    swap right now to either a shorter service interval, or use VX's own 5W30 fully synthetic oil and your annual servicing..
    if i had to have a guess... i'd say the oil is 'gone' and is being used...
    if you changed the oil more often or swapped grade then it SHOULD go back to normal again..
    just because the service book says 20,000 intervals doesn't mean it's a good idea, and the service advisor at your garage should have told you before that it needs servicing more often on the 10W40
    Regular Member Karl's Avatar
    Sunderland
    I know my old 1.8 started to have an Oliver Reed style habit once it hit about 85K (we are talking 1ltr every 800 miles MAX). Thankfully I gave it back to the leasing company before I had to change my name to OPEC
    Wirral
    Blimey, sounds like i'd better give it an oil change pronto
    I'll try to do it this week, MOT is due this week too and to add insult to injury it looks like the rear shocks have failed again at the weekend black splashes all over the back wheels which happened last time they failed.
    Blimey Si it's gonna be an expensive week for you buddy if you fancy poping round one evening i can do the shocks and oil for you no probs !!!!!
  1. Ok, just how many miles has my car done?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 20:59
  2. How many miles..........???
    By mr.smiler in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 22:10
  3. After 500 miles
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 23:42
  4. 100 miles on.
    By accveccysriturbo in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 15:58
  5. 50k miles
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 20:02
