Thread: Is it hard to change oil on 1.9 sri 150
    Redcar
    Default Is it hard to change oil on 1.9 sri 150
    Also where is the oil filter can you get to it from top and what tools would I need to change the oil. Thanks
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    its easy if you have the use of a pit, the filter is at the rear of the engine halve way up!! move the locking clip to one side as you undo the filter not forgetting to attatch a pipe to the little outlet to empty the filter housing as you undo it..
    Inverurie
    Speaking from experience, make sure you can undo the sump plug before attempting any of what is suggested. This way if you can't you can at least still drive the car
    Andy
    Nicking Ya Dinner.
    Sump plug will be tight, get a bar on it if it won't move, but support the the torx/socket end of things with your free hand, and you will need to drop the engine shield, again support this from the front or it will drop and rip, and at £160 a go you don't want that to happen.
  1. Is it hard to change the brake callipers?
    By claudiu666 in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2012, 15:23
  2. why is it hard to change gear??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 10:54
  3. how hard to change the dashboard air bags deployed
    By turbo diesel in forum Bodywork & Interior
    Last Post: 22nd February 2009, 18:39
  4. how hard to change indicator bulb
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2008, 16:42
  5. How hard is to change pads
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2007, 22:48
vectra c sri150 swap
