Thread: whining sound from rear at 70mph??
    Regular Member marky2027's Avatar
    Northumberland
    Default whining sound from rear at 70mph??
    Have noticed over the last few weeks that there is a definite whining, sort of throbbing sound from back of car at 65-70 mph. It is definitely getting worse. When i either slow down or accelarate past this speed it goes. Could this be wheel bearings?? If it is something like that would changing to 225/45/17 have any bearing on things because I changed all 4 in December.
    South east
    Quote Originally Posted by marky2027 View Post
    IMHO wheel bearings would cause a noise at most speeds, not just 65-70 .... the faster you go on dodgy bearings the louder the noise gets. Plus bearings give off a grumbling/rumbling noise, not a whine.
    mansfield notts
    i get the same droning noise at 50+mph noticed it more when i put new tyres on
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    I have a grumbling sound too... Mentioned it at my last service and the stealers changed a front bearing but no change... Left it a while then put it back in... they changed the two front springs. Started to think "maybe it's tyre wear? as the fronts had some excessive wear on the inside edges.... Changed the two front tyres (Asked the bloke who changed the tyres if tracking was out and he said it was highly unlikely as the overall tread although worn was normal....Still noisy a bit mostly while decelerating and around 30 mph... Gonna take it back in again as it's starting to worry me a bit.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    My car's noisy from the rear ... more so at higher speeds. I suspect it's excessive tyre noise from the Bridgestone Potenza RE040's ... I have some 'undulated' wear on the inside of the rear tyres ... my uncle (mechanic) said he's seen it a few times before but has no idea what causes it ... it's a pattern that sort of looks like ___-----___----___---- around the tyre. I've just got used to it now but I do get reminded as to just how noisy it is when I've been in other Vectras that are super quiet.
    Dave
    Apr 2008
    Chesterfield
    Got it on my 1.9cdti estate , check for uneven wear on rear tyres we call it scolloping . Causes all sorts of funny noises.
    Northumberland
    Some days it's worse than others. Since starting this thread I've paid more attention to the sound. It's difficult to describe but it's like a throbbing/warbling sound. Checked my tyres for uneven wear and all ok. Changed the tyres in December for 225/45/17 Vredesteins. It maybe is just tyre noise. Anyway getting 4 wheel laser alignment done soon as driving to france at start of August so we'll see
  1. Sound deadening rear doors
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2012, 21:38
  2. Whining sound from cambelt?? Desperate..please see video
    By claudiu666 in forum Engine & Drivetrain
    Last Post: 25th June 2011, 11:32
  3. Whining sound on deceleration
    By andreitone in forum Engine & Drivetrain
    Last Post: 19th May 2010, 06:05
  4. Strange clunking sound from rear
    By altitude2k in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2009, 09:34
  5. whining sound from rear at 70mph??
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2008, 17:51
whining rear vectra
whining noise tyres vectra rear
