Results 1 to 10 of 17
Thread: Brake lights on full time!
    manchester
    Default Brake lights on full time!
    Hey everyone, dont know if anyone has experienced anything as weird as this before on their veccy . The brake lights on my 2.0 Dti 2004 light up when I start the car, and they stay on, the left, right and the centre one! , hav not moved the car out of the drive now for a week as its a bit risky takin it out.
    Any one with a bit of electrical knowledge have an idea what could be causing this. Getting a light bulb with a ! through in the display aswell.
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    The same thing happend to my old car a skoda octavia, turned out to be the brake light switch. It was located at the the top of the brake pedel. can't be of much help about location on the vec though, sorry!
    East Midlands
    Thumbs up
    Quote Originally Posted by Dean82 View Post
    Yep it's odds on that your brake light switch is stuck in the on position...here's the good news ..cheap and easy fix
    The stop light switch is located on the pedal bracket in the drivers footwell..behind the facsia
    East Midlands
    Thumbs up
    Yep it's odds on the brake light switch is stuck in the on position,you need a new switch..as once there gone there gone,,dealer job about £20 squid i reckon. good news is though it's a easy fix.
    East Midlands
    Sory for the double post,did'nt think it registered first time oh well
    11 Post(s)
    Brake lights work without the ignition being on though, so if it was the pedal switch then they'd be on all the time and not just with the ignition.
    Have you recently changed any bulbs in the rear clusters?
    Birmingham
    More than likely one of the bulbs, had a similar issue with one of my Vectra-B's, turned out that it needed a specific bulb! Take them all out and replace one by one...should hopefully eliminate the dodgy one! HTH.
    Bye bye Vec B
    - Hello Siggy!
    11 Post(s)
    The bulbs in the rear clusters should all be single filament 21w/12 volts.
    Bulbs from top to bottom:
    Turn signal light
    Tail light / brake light
    Tail light
    Fog tail light (works on drivers side only - this is normal for the UK)
    Reversing light
    For the tail light a reduced voltage is supplied to the bulb (to make it dimmer) and when it becomes a brake light the voltage is increased to make it brighter.
    Also, if the upper tail/brake light bulb fails, then the lower tail light takes over as a tail/brake light.
    Regular Member stu28375's Avatar
    Jan 2008
    Colchester
    Big Dave perhaps you can help? I have just checked my bulbs which are in the same order you have listed above, ALL bulbs work fine. Both clusters are in full working order but this si the problem. On Vectra C there should be 2x tail lights on both sides, top & bottom but on mine only the bottom ones work (on both sides). When braking the top ones (brake lights) work normally but dont know why only the bottom tails work. Like I said all bulbs & clusters are working A1. Would really like both tails (2 on each side) to work but cant seem to get them to. Any ideas? All suggestions welcome. HELP BEFORE I GO MAD LOL !!!!!
    Stu.
    manchester
    thanks to all that replied, internet has been on the blink for the past few days, gna check the bulbs as above and if not will check the switch on the pedal. I hope its just a mix up with the bulbs.
    Will update when av checked.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. service parts .. time to become a full member?
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 15:09
  3. Brake Lights on All Time
    By mcwharam in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 16:36
  4. Full brake bleed
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 20:06
