Thread: Tyre test
    Default Tyre test
    Thanks to Michelin I am now conducting a test of two slightly different Michelin tyres on my Vectra C 3.0 V6 CDTI
    I used to have Michelin HX MXM 205/55 R16 91V tyres on my Vectra B SRI 140, and I was so impressed with them I also bought them when I had my Mondeo Mk3 Ghia TDCI
    However, the Vectra C came with Good Year tyres and the NCT5 215/50 R17 95W XL are over-priced, with numerous horror stories over bad batches
    I then changed to the Eagle F1 GSD3 225/45 R17 94W XL
    Michelin have supplied me with two tyres to test, which have both been fitted to the front
    The rears are still a pair of identical Eagle F1 94W XL
    On the nearside :
    Michelin SP Primacy 225/45 R17 94W XL
    This is a three compound tyre with an assymetric pattern
    On the offside :
    Michelin SXE Primacy 225/45 R17 91Y
    This is a six compound tyre with the same assymetric pattern
    Their tread pattern is also identical to that of the HP Primacy, which is due to be replaced later this year
    The SP Primacy looks a chunkier tyre, compared to the SXE Primacy, but this may be due to the different construction method
    Initially handling is very different to that of the Good Year NCT5, which was previously fitted on the front
    The directional control is slightly improved and sharper
    Ride quality is slightly worse, but that is due to the lower profile and higher tyre pressures
    Road noise is much less than the NCT5 as well
    I will report back on wet handling, when it happens!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    how did you manage that then m8
    One of my contracts is to perform tests on tyres from cars involved in serious accidents
    The tyres are sent to Aberdeen University where we use the equipment there to perform the tests
    One of our main contacts is with Michelin tyres and they provide most of the "base" data
    We also do a range of other tests to compare tyre performance
    Occasionally we are asked to perform trials on new tyres just before they are launched on the market
    I last did a trial for Michelin, also on the HP Primacy before it was launched
    At the time I had Michelin HX MXM tyres and didn't like the HP Primacy
    Michelin have supplied me with two tyres to test, which have both been fitted to the front...
    ...On the nearside :
    On the offside :
    This is a six compound tyre with the same assymetric pattern....
    ...Initially handling is very different to that of the Good Year NCT5, which was previously fitted on the front
    But how on earth can you give a detailed, or even accurate, report on the performance/handling of a tyre when you have two different types fitted to the front wheels?!
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Plus personally I'd be seriously concerned about wet weather performance differing between the two given a comparatively high front end load that the 3.0 diesel lump will give.
    From a personal point of view, I had 4 Michelin Primacy HP 215/50 R 17 91W on my 3.2, and they were the worst tyre I have ever come accross. The wear was high, the grip mediocre and they have proven impossible to balance properly.
    Thankfully the fronts have worn out and I now have Pirrelli P7s on the front - and even Kwik Fit can balance thos with no trouble at all.
    probably having 2 different tyres with different compounds is to see which 1 will give more miles and to see how they wear across the whole tyres. as when he has finished with michelin will strip then down for there reports
    The two front tyres are almost identical when you look at their tread impact
    Even under load the total area and shape of the contact surface area is identical
    The main difference is in their construction
    The tyres are being removed after 5,000 miles, which should be about 8 weeks
    Another pair of tyres will then fitted, but in reverse, and again removed after 5,000 miles
    The results will then be compared
    These tyres were removed today
    Fitted to the front at 52652 miles
    Removed at 59859 miles, net 6207 miles
    That's pretty awful when you compare the Good Year NCT5 tyres lasted 13357 miles on the front
    I am now back on a full set of Good Year Eagle F1 GSD3 tyres, the new tyres fitted to the rear and the old rears swapped to the front
    I've got a week to decide what the next test is for, it's either :
    Pirelli P Zero Rosso
    or
    Michelin Primacy
    or
    Continental Sport Contact 3
    Again, each tyre will be slightly different and fitted to the front
    Time for this years tyre test
    On the nearside :
    Michelin Primacy HP 225/45 R17 94W XL
    On the offside :
    Michelin Primacy HHE 225/45 R17 94W XL
    This is a new four compound tyre with the same assymetric pattern, due to be released from June 2011
    All was going well on the dry test
    However, on examining the offside tyre it was found to be a complete failure
    It was replaced by another new identical tyre
    This passed the dry test and we moved on to the wet test
    However, on examing the offside tyre it too was found to be a complete failure
    As a result all tyres have now been removed and the two failed ones sent for examination
    There was a lot of head scratching from the technicians from Michelin
    At least it wasn't just my car, as the same issue occured on eleven of the twelve such tyres
    The tyres were specifically produced for these tests
    Normally after these tests we then get to keep a set and report back
    However, that did not happen this time, the original Good Year tyres being put back on my car (rather embarrassing for Michelin)
    I was then advised there will be another test scheduled as soon as possible and if not before the end of June then I will receive two free tyres through National Tyres
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Michelin primacy hp 225/45/17 94 w xl is what i have on the fronts & back.
    Well happy with them, no issues in the dry or wet.
    Will be good to see your results.
  1. Tyre Test - Syron Race 1
    By spoons in forum Handling & Braking
    Last Post: 5th July 2012, 17:34
  2. Boost leak test using spare tyre?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 12:08
  3. 50 tyre test
    By Ziggy in forum Handling & Braking
    Last Post: 9th March 2012, 15:27
  4. auto express tyre test 2007
    By Mike57 in forum Handling & Braking
    Last Post: 8th November 2007, 14:48
