Thread: What needs changing...
    Northampton, UK
    confused What needs changing...
    Hi all, my Signum 2.0T Design, has reached 60000 miles now, so I was wondering, what should i think about having replaced or done to keep her healthy and running? I've read threads about water pumps, cam-belts, timing chains... so any help would be great.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    nowt .... usuall service parts...
    How old is the car?
    How many services has it had, when, and at what intervals?
    60K miles...
    Probably doesn't need a cambelt change, if it was done at 40K miles
    However, you might want to consider one at the next service interval
    Depending on how and where you get it serviced, perform a check on the waterpump, although some people change it along with the cambelt irrespective
    Apart from that, keep to the service schedule
    Other things you may also want to change :
    upgrade from semi-synthetic to fully-synthetic oil as part of the oil and oil filter changes
    increase the frequency of oil and oil filter changes
    increase other service item renewal frequencies
    increase MoT inspections to 6 monthly
    However, servicing is more about identifying components that have failed or are close to failure
    If you are using the car every day, then you as the owner and driver are more likely to spot them, than a VX mechanic!
    The only change I make when the car goes out of warranty is to increase the frequency of services, usually cutting it in half, so for may car that will be 1 year and 15K miles
    I already have MoT carried out on my car every 6 months, usually within 4 weeks of a service
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Thought the 2.0T was a chain not a belt, so won't need changing.
    Quote Originally Posted by benny View Post
    However, you might want to consider one at the next service interval...
    The 2.0T doesn't have a cambelt, it has a timing chain which doesn't have a replacement schedule.
    n-hudson - all you have to do is make sure the car gets serviced regularly. I personally do it to schedule with oil/filter changes every six months/10,000 miles. Use the 5W/30 fully synth oil. Being a turbo engine the oil needs to be in tip-top condition, so changing it often will only do good.
    As for things like water pumps, well basically replace only if it goes wrong. With there being no cambelt to change, it's not something that you would/could do at the same time - only if it ever goes wrong.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    my vec dti is just around, 120,000 miles....all i do is get it serviced every 12,000. which in my case is about every 10 months,and oil filter every 6,000 in between major service (or every 5 months).........
  1. Changing GID to CID
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2013, 14:36
  2. How F1 Is Changing
    By VauxVeteran in forum Motorsport / Formula 1 etc. chat
    Last Post: 23rd March 2008, 22:06
  3. Help with changing my car please
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 20:41
  4. why am I changing my car ?
    By rob 2.2dti in forum General Chat
    Last Post: 30th May 2007, 23:56
  5. changing again ?
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 20:50
