Thread: Rainsensor
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Default Rainsensor
    My new rainsensor is tech 2'd in and the garage say there are no faults in the system but it still does not work they want £190 to fit a rainsensor as the replaced windscreen means the warranty is not valid because of this any clues anybody any fuses to check in case etc?
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    All i can tell you is its powered off the REC and thats about it.... I could hook the laptop to it and it would have told you if it detects the rain hitting the screen. But unless your coming to PVS then I think your options are quite limited
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Cheers for the offer unfortunately I won't be at PVS. It has been checked on Tech 2 and all seems in order no fault codes and I have checked the voltages with a multimeter and there is a permenant feed and a switched ignition feed onm the outer 2 pins and 99ohms on the centre pin. The stealers reckon the sensor is faulty but I don't understand why it intermittent wipes instead of doing nothing on the first position.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by paulhb View Post
    ... I don't understand why it intermittent wipes instead of doing nothing on the first position.
    The rainsensor can be disabled via Tech2... is there any chance that this has been done?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    No it is definately active according to the garage and there are no faults in the system and there is voltage present at the plug they want £187 to replace it.
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    well if the windscreen was replaced and the rain sensor doesnt work call the guys who fitted the screen! oh and £190 for a sensor jog the F**k on, you can get these for less than £50 new and even cheaper second hand! takes less then 5 mins to fit, pop off the plastic cowling un-hinge the silver metal connectors gently prise out the sensor and then unclip the flimsy plug / wire. very very easy mate
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I know its easy I have removed it to try and test the voltages but the stealers price is £99 plus the dreaded where can you get them for £50?
    Jul 2006
    mmmmmmmmmmmm
    I used to work for RAC Autowindscreens so they got them but they were no-where near £100 plus vat was £30 plus vat! Even a second hand one will do, all you do is turn ignition on then spray a bit of water over the sensor with the wiper stalk on setting one.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Autoglass won't help they say its my fault because to make it easier for them I removed it all in advance to make the job go quickly and also because I have had problems with the connectors myself and replaced the roof loom once already, how do I get a new one at £30 +vat go to Autoglass and ask them to supply one?
    Jul 2006
    mmmmmmmmmmmm
    you could, they get them fairly cheap but then they wil add cost on to you.
    AutoGlass ses it all really, make sure that they used rust proof primer on your aperture, if not you'll soon have rust building up very rapidly as all water runs down those sides and trickle into the scuttle panel, not only that but also jepodises the integrity of the windscreen.
  1. Retro fitting rainsensor
    By sulten in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 19:17
