Thread: Oil Level Sensor
    Nov 2007
    Bournemouth
    Default Oil Level Sensor
    Hi does anybody know the location of the oil level sensor?
    Or, more to the point, any ideas as to what would cause the oil light to come on? It usually seems to come on after about 30 minutes driving. Oil level at cold is fine. Im assuming blocked/restricted oilways or something?
    Gavin
    Nov 2007
    Bournemouth
    Anybody got any ideas on this?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    I had a similar problem on a Vectra B SRI, the MFD kept coming up with Check Oil Level after about 30 min m'way driving....went to Vx, they said dont worry about it as the sensor is in the sump....meaning a complete strip down and another oil change to change....so as they said, I though S0D That and just kept checking the oil level before a run. Maybe located in the same place!
    it is indeed in the sump..easyish to change and relatively cheap part to buy..
    Nov 2007
    Bournemouth
    Hmm, confused about this now. I found the sensor at the front of the sump, and disconnected the wiring from it. Took it on a test run, and the light still came on after a while of driving. Is there anything else that would cause the low oil light to come on? I'll have another look around the sump tonight to see if i can see another sensor I have missed.
    If the wiring isn't connected to the sensor then it's obvious that the light is going to come on
    However, it's probably based on the oil temperature, so more than likely another sensor at the top of the engine
    the oil level warning light has nothing to do with a oil temp sensor..
    it will be a failed level sensor going open curcuit.. change the level sensor if the oil level is correct to the dipstick..
  1. For Sale: AFL level sensor
    By plasma in forum Parts for sale
    Last Post: 11th October 2012, 16:50
  2. Oil level sensor
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 16th August 2012, 21:49
  3. Oil level sensor ?
    By draca in forum Engine & Drivetrain
    Last Post: 2nd September 2011, 07:51
  4. Where is the Oil Level Sensor
    By rocket999 in forum Engine & Drivetrain
    Last Post: 30th August 2011, 20:07
  5. self level sensor?
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2010, 19:54
