Results 1 to 10 of 14
Thread: WTF!!!
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default WTF!!!
    Driving to work yesterday I thought the gear knob was a bit loose and just gently lifted it whilst driving and it came of the stick.
    After checking the inside of the knob, which is mounted by what looks like splines that line up with splines on the stick, but were worn enough that the knob was not a tight fit no more. So in order to do some thing very quickly for obvious reasons, I had to turn it around 180 degrees for it to fit again.
    Questions are:
    1. is this covered within the three year warranty?
    2. has any one else had this problem.
    3. Is it time to change over to an Irmscher version
    Seriously guys I would be obliged for your feed back on this.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mine has started to click recently, think it's the start of it coming off... must be the weather.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    1) would only be covered by VX's 1 year warranty.. fixtures and fittings/interior.. (3 years on mechanical)
    2) seems a few people have had them popping off!!
    3) Go for the irmscher version,,, you know it makes sense!!
    all i have ever done is put some epoxy glue on it, line it up and tap it back on with a softface mallet.... works every time..
    Dec 2005
    West Lothian
    I thought of doing some thing like that but was thinking that perhaps the gear knob might have to come back off for any reason/repairs etc. If not then I might just glue it back on.
    Dec 2005
    West Lothian
    Quote Originally Posted by lofty View Post
    Lofty thats the tell tale signs of it ready to come off. Thats what mine did a couple of days prior to it coming away. I thought it was just needing adjusted or some thing Get the glue ready mate.
    Dec 2005
    West Lothian
    Quote Originally Posted by Dwabo View Post
    Hi Dwabo, I thought that would be the case. VX crap again, when they can't even guarentee a gear stick knob lasting any longer than 12 ferking months
    @home
    Engine : 1.9 CDTi
    works every time..
    how many times does it come off????
    Quote Originally Posted by KC View Post
    Maybe time to get a VXR/Irmscher one then
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    You want to be Careful putting Epoxy resin on your Knob !!
    Dean
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    Dean
    LMAO
