Thread: Air-Con stinks!
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Default Air-Con stinks!
    Following on from my last post in this thread, http://forum.vectra-c.com/showthread.php?t=49460&page=2, anyone got a cure for this?
    Paul.
    Snowman, you got your ears on?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Have you had a read of this thread?
    http://forum.vectra-c.com/showthread.php?t=48137
    Oct 2007
    Horley, Surrey
    Ah ha!
    Cheers Lofty.
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Taffyopel View Post
    Ah ha!
    Cheers Lofty.
    You're welcome - hope you get it sorted..
    Oct 2007
    Horley, Surrey
    Removed pollen filter, not too bad, air-con at full chat, temp set half way so flap opened on heater box and away with the anti-bac spray. Also gave the pollen filter a dose. Temp switch then back to cold and left air-con going for about 10 mins then turned off and waited for the smell of Satans socks.........................and no smell!!!!!!!
    This is obviously the best and cheapest remedy as i've tried the cannister you let off in the car and to be honest, it was cr4p. There was a lovely orange smell and the inside smelt like a Jaffa Cake factory but that only lastest about half an hour then it went. There's no way it's gonna suck the stuff into the heater system as good as actually getting stuff directly into the fan area.
    Lofty,
    @home
    Engine : 1.9 CDTi
    Gonna have to do this myself as mine is just starting to smell as well.. It's due a service so will wait till after that and see what it's like..
    Sunny Dartmoor
    Result there Taffy........
    Oct 2007
    Horley, Surrey
    Sure is Glenboy.
    Just been to pick the missus up so had the air-con running for at least 20 mins. Turned it off 5 mins before home with just the fan blowing and no smell. Woo Hoo!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    An alternative method that also works is to put the AC on full blower with re-circ on then spray fabrize (or other, like detol) into the passenger footwell area, so it gets sucked into the system and close the doors and leave for 5 minutes blowing. Works a treat and kills all the bacteria and smells.
  1. Clutch stinks...
    By strela in forum Engine & Drivetrain
    Last Post: 17th October 2012, 11:18
  2. Air Con STINKS!!!!!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 30th July 2010, 12:00
  3. My Cat Stinks!
    By ghostrider in forum The 'Off Topic' room
    Last Post: 4th January 2009, 19:14
