Thread: Chain or Belt?
    Jan 2006
    Bedfordshire
    Default Chain or Belt?
    Hi All
    New user herem first post, so be gentle...
    My 2.2 SRI has now done 72,000 miles without fault, and will hopefully go on for another few years yet. Great car, does all that I need.
    BUT does the 2.2 have a timing chain or a cam belt (and if its a belt, do I need to change it?)
    Vx typically vague on this, hoping you can help me out.
    Leicester
    2.2 Petrol has a chain.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep chain I believe mate, don't know about the service though mines only done 20000. And welcom to the site, there is always somone here that can answer any and all your questions.
    Deffo chain m8 ..........And welcome !!!!
    south yorkshire
    be very careful mate,i had a vectra sri 150 which has the same 2.2 engine and the cam chain snapped at 33500 miles.result one wrecked engine!.i was very lucky as vauxhall sorted it free of charge.good job as it needed new cylinder head,valves,pistons,oil pump,cam chain and lots of other parts.im led to belive about a couple of grands worth.once sorted i got rid of the car and bought the signum which in my opinion is far better.this problem is common on this engine,something to do with the oil spray that lubricates the cam chain.you have been warned.
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Wow not to worry
    Quote Originally Posted by gary
    Yes you are correct, but I beleive that Vauxhall have sorted out the problems with later versions. best to check when the mods were introduced and check the dates against the age of your motor for peace of mind. Or you can just change it to be safer if you wish!!
    SCOTLAND
    This was a problem on the early 2.2 engines and mostly affected veccy b and astra's. Vauxhall added larger oil sprays so that they wouldnt clog up so as long as you do regular service and oil change you should be fine.
    Welcome to the site by the way.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Graeme is right
    The spray hole blocked due to dirt deposits thus reducing lubricating oil onto the chain, hence breakages. Spray holes improved later by VX
    Regular servicing with quality oil should prevent this problem occuring.
    Jan 2006
    Bedfordshire
    Many Thanks guys, much appreciated
  1. belt or chain
    By renblade in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 02:03
  2. Belt or chain ????
    By irmscher-brett in forum Engine & Drivetrain
    Last Post: 19th February 2010, 11:10
  3. Chain or belt?
    By Gripper in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 11:19
  4. Chain or Belt??
    By willc01 in forum Engine & Drivetrain
    Last Post: 4th July 2007, 15:51
  5. Cam Belt or Chain
    By ROB WOODHOUSE in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 17:33
https:www.vectra-c.comforumshowthread.php4985-Chain-or-Belt
