Thread: Towbar electrics
    Regular Member amiddleton's Avatar
    May 2008
    Hull
    Default Towbar electrics
    I have just purchased a towbar and genuine electrics to plug into my 06 Veccie. In the instructions is says it has to be tech2 and the stealer wants £79 for this due to tech2 and reprogramming.
    I friend just done his and it works fine. Should i have it Tech 2 ????
    Cheers in advance
    Some cars need it Tech 2d in, some don't. I'd get it all fitted first and see if, like your friend, yours also works. If it does then no Tech 2 needed.
    BTW £79 is taking the pee big time for something that takes five minutes!
    May 2008
    Hull
    Apparantley £52 for the tech 2 part and the rest to reprogram, i am going to just fit and see as i have spent £168 already on the bar etc (Big Sigh)
    Quote Originally Posted by amiddleton View Post
    Apparantley £52 for the tech 2 part and the rest to reprogram,..
    Tech 2 and reprogram are the same thing i.e telling the car, if needed, that it has the module. Don't understand why they've quoted Tech 2 and reprogram as different 'items'.
    ...i am going to just fit and see as i have spent..
    Yep, deffo best option. There's a good chsnce it won't even need a Tech 2.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    would you need it tech2'ing if you had factory reversing sensors?
  1. Towbar Electrics
    By slipperysam1984 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2010, 15:53
  2. Towbar Electrics
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2009, 19:05
  3. Vx Towbar Electrics
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2006, 08:42
  4. Towbar electrics
    By CPHB in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2005, 21:28
